95 Gc Stalled - Won't Start Now Gas Smell - JeepForum.com
post #1 of 2 Old 03-11-2004, 12:28 PM Thread Starter
phjohnso
My son's 95 jeep gc 5.2 v8 stalled on the wat to schooll this morning - he tried to start it but all it would do was turn over and there was a slight gas smell. Had it towed home and let it sit fo a few hours - tried to start it a few times with no luck, same thing, slight gas smell.
I am thinking dist cap, rotor and coil replacement for starters. I have searched the other posts on here and this seems to make the most sense - any other thoughts???
phjohnso is offline
post #2 of 2 Old 03-11-2004, 01:00 PM
greasefingers
greasefingers's Avatar
1994 ZJ
I would not replace anything until you confirm that there is spark. Pull the coil wire and hold it close the engine head. If you do have spark then it could be the fuel pump; which you can check with a gage. Smelling gas is more common on carbureted engines. Especially after a back-fire. It's not as common on fuel injection systems. So this is curious. Also, if the computer/PCM senses no spark, then it shuts off the fuel pump via the automatic shutdown relay. The relays in the PDC, seem to be robust. I have not heard of breaking down, yet. Hope this helps.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
00 GC stalled and won't start mattpm07 ZJ Grand Cherokee Forum 4 08-07-2009 04:40 PM
Help! ZJ stalled and won't start! aaron7 ZJ Grand Cherokee Forum 3 12-09-2008 11:44 AM
My Jeep stalled & won't start! robskeeter ZJ Grand Cherokee Forum 0 08-23-2008 04:03 PM
Put in reverse... stalled... won't start now aaron7 ZJ Grand Cherokee Forum 19 11-21-2007 08:43 AM
Stalled now wont start Jay1982 ZJ Grand Cherokee Forum 16 06-25-2006 03:20 AM
