'95 GC Ltd A/C compressor replacement - JeepForum.com
post #1 of 6 Old 03-19-2007, 11:44 AM Thread Starter
Phant0m51
What engine/years are interchangeable with the '95 5.2L? Would it be possible for me to get an A/C Compressor off of a 4.7L? Or am I going to have to stick with the 5.2 of a 97-98, or whatever I can find?
Phant0m51 is offline
post #2 of 6 Old 03-19-2007, 04:20 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
you shouldn't have a problem locating 5.2L AC compressor. They go for around $400-450 new to $250-350 for reman. unit(with clutch assembly)
zaq123 is offline
post #3 of 6 Old 03-19-2007, 05:08 PM
a70eliminator
What makes you suspect the comp. is bad?
a70eliminator is offline
post #4 of 6 Old 03-20-2007, 08:50 PM Thread Starter
Phant0m51
The reason I think the compressor is bad is because the clutch on it is completely frozen and is now melted to high hell.
I know I can find a new/rebuilt compressor, but I can't afford to spend that much. A Junkyard tear-off is my only option, which is why I asked if I could take one from a different motor.
I'll have to check the big junk yards 20-30 miles away to see if they've got a 5.2.
post #5 of 6 Old 03-20-2007, 09:03 PM
driabyor
driabyor's Avatar
1994 ZJ
replace the clutch... if it's burned up... chances are the compressor is still good.
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #6 of 6 Old 03-21-2007, 10:52 AM
SirFuego
Here's what I do when I check for "compatibility" issues:
1) Fire up google
2) Search for a site that sells the part in question (AC Compressor in this case)
3) Put in your vehicle information
4) Write down the part #
5) Start changing the vehicle information (I6, 4.7L, WJ, XJ, TJ, etc)
6) Check if part # is the same -- if it's the same, they are compatible
For better results, try this on multiple sites. If they all agree, it's unlikely for them to all be wrong.
You now know what engines/vehicles to look at when looking for a used part.
93 ZJ with tube
SirFuego is offline
Is my A/C compressor bad? VoteWithABullet ZJ Grand Cherokee Forum 8 06-13-2008 04:52 PM
AC Compressor beardman2 ZJ Grand Cherokee Forum 4 04-30-2007 12:06 PM
A/C Compressor Clutch replacement - Anyone? oneillsean ZJ Grand Cherokee Forum 6 04-24-2007 04:14 PM
Do I need a new A/C Compressor? Skyline ZJ Grand Cherokee Forum 4 07-04-2006 12:29 PM
AC Compressor Wylde33 ZJ Grand Cherokee Forum 15 12-02-2005 10:35 PM
