95 CHEROKEE ROUTINELY DOWNSHIFTS from 4th/ovrdrv - JeepForum.com
post #1 of 2 Old 07-09-2002, 08:34 AM Thread Starter
joe-doggs
Dear friends,
My 1995 4.0L equipped Grand Cherokee very occasionally shifts out of 4th/overdrive on the freeway - Ive noticed that when this happens - the overdrive off/on button indicator light is illuminated - do you thing this is related to the trans over heat circuit ? The engine is not overheating when this occurs ? any ideas would be appreciated.
joe-doggs is offline
post #2 of 2 Old 07-09-2002, 06:43 PM
Drafter75
It's entirely possible that this could be a trans overtemp problem. An overtemp condition will take the trans out of OD until it cools down. I'd suggest making sure that all radiators and coolers are free and clear... find out what could be causing your trans to run so hot.
While I don't think the trans overtemp circuit is tied into the engine temp, a higher running engine temp would contribute to higher trans temps. Consider adding an aux trans cooler?
Drafter75
Proud V8 ZJ/WJ owner of
1993-1998-1999-2002 model years.
Have you hugged your Jeep today?
Drafter75 is offline
swapping a grand cherokee rearend for a cherokee dana 44 is it strait bolt in kojak70 ZJ Grand Cherokee Forum 2 11-02-2009 12:44 AM
My Wife's 2006 WK downshifts VERY hard nationm WK Grand Cherokee & XK Commander Forum 6 09-11-2009 04:48 PM
WK transmission clunking on downshifts themow WK Grand Cherokee & XK Commander Forum 5 08-16-2009 07:29 PM
Will A 242 Transfer Case From A 90 Cherokee Fit In My 99 Jeep Grand Cherokee.?? squirrly ZJ Grand Cherokee Forum 8 03-05-2009 06:55 PM
4.0 Cuts out, downshifts randomly bfisher83 ZJ Grand Cherokee Forum 12 02-03-2009 01:17 PM
