Quantcast 95 4.0 stalls when off the gas - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 95 4.0 stalls when off the gas
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 03-02-2009, 01:38 PM   #1
liredneck
liredneck's Avatar
Ok my 4.0 is stalling when I'm not on the gas not all the time butt enough to to bother me . If I putt it neutral it starts right back up most of the time sometimes I have to pull of the road and wate a min or so somtimes I will run at an idell for ever and others it will stall at a red light any body got any idears
97 tj 6 cyl 5 SPd 4" supelift 35" baja claws 8.8/hp 30 ,4.10 lockrite in the rear , RR sye and adams dc shaft ,10k lb viper winch and other crap
liredneck is offline   Reply With Quote
Old 03-02-2009, 01:43 PM   #2
HD-ZJ
Check vacuum hoses first
PCM connections second
Fuel filter third
HD-ZJ is offline   Reply With Quote
Old 03-02-2009, 01:50 PM   #3
jimjam515
Make sure the throtle body and idle speed control valve are clean, I've just had to replace my ISCV due to it going bad on a '96 Grand,
Regards,
Mark
jimjam515 is offline   Reply With Quote
Old 03-02-2009, 02:59 PM   #4
HMX
1994 ZJ
If none of the above fixes the problem, you might have a bad vehicle speed sensor (VSS). Screws into the transfer case and has a two-wire or three-wire plug. Costs about $60 at Autozone.
dan
HMX is offline   Reply With Quote
Old 03-03-2009, 10:07 AM   #5
liredneck
liredneck's Avatar
Tryed the PCM thing on off on off on and the light just stays on no blinky blink could it be the PCM
Old 03-03-2009, 10:40 AM   #6
liredneck
liredneck's Avatar
And when it is running in park tv rpm is just above 0 butt I thought the gauge might be wrong with the 220000 miles of has on the body the motor is new about 1500 miles
Old 03-04-2009, 04:22 AM   #7
liredneck
liredneck's Avatar
Did all of that anything eles
Old 04-20-2009, 05:15 PM   #8
projectawesome
i have a 02 doing the same thing did you have any luck?
projectawesome is offline   Reply With Quote
Old 04-20-2009, 07:45 PM   #9
98BlackZJ
98BlackZJ's Avatar
Mine acted like that when the TPS went bad.
98BlackZJ is offline   Reply With Quote
Glock Forum
