95 4.0 fuel pump pressure? - JeepForum.com
post #1 of 3 Old 03-11-2008, 01:43 AM Thread Starter
my2monkeys
1989 XJ Cherokee
Can anyone tell me FSM sspecs on my 95 4.0 fuel pump pressure? I put a gauge on it and it reads 40 psi at idle. Sound about right? Problem is , vehicle chugs under accelleration sometimes and sometimes not. Thought it was pump because it was doing it badly once, and I was almost empty so I filled her up and it immediately ran good. So I figured low fuel=hot pump, but the wife says "no chug on low fuel and chugging with half tnk ". Problem comes and goes, mostly comes. Any ideas welcomed!
my2monkeys is offline
post #2 of 3 Old 03-11-2008, 09:16 AM
kmd1776
im in class right now, but if i remember correctly, the FSM says 39 psi +/- 1 psi for my 95 FSM
04 wj limited; 4.7L V8, 247> 242hd swap; Hayden auxillary tranny cooler; BFG All Terrain 245/70/17; Moog Up-Country Coil Springs; Monroe Reflex Monotube Shocks; JKS BPE's; Chrome Overland tow hooks; Dynomax Ultraflow catback
kmd1776 is offline
post #3 of 3 Old 03-11-2008, 09:20 AM
kmd1776
and when you mean "chug" what do you mean buy that? is the tach bouncing around?? or that you think your getting lots of fuel, then little fuel?
kmd1776 is offline
New power steering pump and pressure hose, now excessive pump noise Jeeples ZJ Grand Cherokee Forum 14 03-15-2011 04:59 PM
fuel pump?pressure regulater? chevyguy111 ZJ Grand Cherokee Forum 1 05-18-2009 03:15 PM
No fuel pressure, Fuel Pump? CPS? ECU? Relay? 95cherokee33s ZJ Grand Cherokee Forum 2 10-22-2008 09:57 PM
Fuel pump & oil pressure switch Wiley ZJ Grand Cherokee Forum 43 11-12-2006 05:06 PM
Fuel pressure and pump rkreger2 ZJ Grand Cherokee Forum 9 08-18-2006 12:20 AM
