94 zj security system problem - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 94 zj security system problem
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-23-2014, 11:12 PM   #16
sethwag
1994 ZJ
I don't think the chime module does really anything with the security system, but, if you bend the corresponding pin down, then the door locks function correctly and all that jazz. Sorry about the confusion with the security module.
Originally Posted by KoreaZJ View Post
Should be two wires on Pin #5, DB and YL/DG
sethwag is offline   Reply With Quote Quick reply to this message
Unread 02-26-2014, 09:13 AM   #17
sa1994zj
1994 ZJ
yes i have know about the lock sencuences however my back lock is broken and the lock in the drivers door is not there
sa1994zj is offline   Reply With Quote Quick reply to this message
Unread 06-16-2014, 11:44 PM   #18
BigDaddy02
1994 FSJ Cherokee
Originally Posted by WhiteOut View Post
You don't need to mess around with the security module, the alarm is bypassed right now and when you grounded out that wire, you did not cause the drain.
Sounds like the internal mechanism of the hatch is broken, it's a fairly common issue. You need to remove as many screws as you can from the interior trim on the hatch, then reach down and pull the threaded rod up to open the hatch. Once the hatch is open, the remaining screws can be removed the entire trim piece removed. Reconnect the threaded rod to the mechanism and cross a pair of zip-ties over the connection point to keep it in place.
So can you leave the wire grounded.. Or do you have to ground it every time.
BigDaddy02 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2014, 12:06 AM   #19
BigDaddy02
1994 FSJ Cherokee
{quote}
Can you leave the ground on the purple and yellow wire. Or do you have to ground it every time the security goes off.
1994 zj , alarm system , anti theft , security console , zj
