94 ZJ Power Living Room Seats - JeepForum.com
post #1 of 3 Old 04-30-2013, 10:20 AM Thread Starter
SheepJeep
so i swapped some 94 zj seats into my 01 xj but kept the manual seat bracket in the xj so now i have a pair of xj seats, a set of 94 zj non heated power seats brackets, and a need for some living room chairs
this is more a "because i can" project than anything else but i want to plug in the seats into a wall outlet and make it so you can adjust your seat. I want to see a wiring diagram for the seats to figure out how to do this, what is in between the batters and the seat and how big of a 12V DC adapter i need
the plug on the seat is an oval with two contacts on it
SheepJeep is offline
post #2 of 3 Old 04-30-2013, 10:52 AM
abraham743
Power and ground on the wiring. If you wire them up and they move the wrong way just switch your wires. As far as in the vehicle there was probably a 20 or 30 amp breaker. Look in fuse section of owners manual.
abraham743 is offline
post #3 of 3 Old 04-30-2013, 11:45 AM Thread Starter
SheepJeep
the fuse blocks says 30 amps (circuit breaker), so i would assume that's 15 amps per seat
thats what i assumed with the connector pins but wanted to be 100% that is wasn't something like x-motor and y-motor and ground through the floor
