94 ZJ Lift Done ....feels sloppy - JeepForum.com
post #1 of 6 Old 08-02-2009, 05:30 PM Thread Starter
jnjtrevino
1994 ZJ
I finished my IRO lift finally 3.5 f-r with adjustable rear trac bar, now that it is done it feels really sloppy... any suggestions where to start ?
I know the ride wont be like a stock zj ....is this just what I should expect from this lift....
Maybe I should quit looking for the easy answere and just climb underneath and get busy ....any suggestion would be great ....Thanks
You laugh because I'm different...........
I laugh cause I just farted!
jnjtrevino is offline
post #2 of 6 Old 08-02-2009, 05:32 PM
gatorayde
Be more specific by what "sloppy" means. Steering, body roll, shocks, etc?
gatorayde is offline
post #3 of 6 Old 08-02-2009, 05:36 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Any time you lift and put bigger tires on, it's gonna feel more 'sloppy'.
You will get more body roll. You will get more tire roll.
It will be more sloppy.
You will never get anywhere near a factory ride from a lifted Jeep.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 6 Old 08-02-2009, 05:48 PM Thread Starter
jnjtrevino
1994 ZJ
it is wandering alot which i think is going to become an alignment issue...but it feels like the body is rolling more ...it might be that I just need to finish tweaking things a bit ...and get used to the different ride ...Problem is I have not driven the jeep all of 5 miles since I bought it ...so I might have more issues then I think in the suspension... but hey what do you expect for a $100 DOLLAR ZJ ... Bought it being told the motor was bad ...so I bought a rolled ZJ for the motor but it turned out the cat was plugged....repleaced that and she runs like a champ... and I have a backup 5.2 in the garage...I was just hoping for the easy answere ...which I know isnt there ...just hoping for ideas
post #5 of 6 Old 08-02-2009, 05:59 PM
ZJ_Richie
Get the alignment, that might just be the issue. You will get used to the ride eventually.
3 in. Pro Comp lift with crawlerready 2 in. spacers, longer than stock control arms, front adj. track bar with IRO hd mount, rear adj. track bar, jks discos, Currie Currectlync, black soft 8's with 32 in. Hankook Dynapro mts
Future mods: hp30, 8.8 swap, IRO's 5.5 Critcal Path Kit
ZJ_Richie is offline
post #6 of 6 Old 08-02-2009, 06:29 PM
gatorayde
You need an alignment before anything else. Your toe-in will be out of whack because of the tie rod/drag link design on the zj's. Body roll gets worse the more you lift it, just don't drive it like a race car around turns.
sloppy steering afss ZJ Grand Cherokee Forum 11 11-15-2008 06:41 PM
Sloppy Steering In 97' ZJ ThroatyStang ZJ Grand Cherokee Forum 8 02-22-2008 11:31 PM
Sloppy Steering Still micifus ZJ Grand Cherokee Forum 10 03-25-2007 07:01 AM
Sloppy ZJ steering ajaxajax2000 ZJ Grand Cherokee Forum 20 01-16-2007 09:01 PM
Sloppy Steering mr_user ZJ Grand Cherokee Forum 2 12-22-2004 09:05 PM
