94 ZJ has a squeak - JeepForum.com
post #1 of 15 Old 04-04-2008, 11:35 AM Thread Starter
NEp8ntballer
94 ZJ has a squeak
So at low speeds(5-20ish) my 94 only makes a squeaking sound when turning. It has to be in a 90 degree turn. makes the noise when turning to the left or right. sound comes from the front left. It isn't constant, it gets loud and then it fades out only to get loud again. I have a 4.0 with the auto trans if it makes a difference.
NEp8ntballer is offline
post #2 of 15 Old 04-04-2008, 11:50 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Could be tie rod ends. Lube up the front end with a grease gun and see if it helps.
Jeep Sold! 02/2009
Need AMSOIL?
LaCeS OuT is offline
post #3 of 15 Old 04-04-2008, 01:16 PM Thread Starter
NEp8ntballer
I've already given the tie rods a good shake and they are all solid.
post #4 of 15 Old 04-04-2008, 01:23 PM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Im not saying loose, but sometimes lack of grease could cause a squeaking sounds. Also, recently I had a squeaking sounds and it ended up being my trackbar. I greased it up and it went away.
Jeep Sold! 02/2009
Need AMSOIL?
post #5 of 15 Old 04-06-2008, 09:38 PM Thread Starter
NEp8ntballer
hmmmmmm, maybe it's that tie rod end with grease oozing out of everywhere yet is still solid.
post #6 of 15 Old 04-07-2008, 06:39 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Check the trackbar TRE. It can cause a squeak when turning, like I said it happened to me before. If you are stock, I have a brand new stock trackbar for sale. PM me if you need it.
Jeep Sold! 02/2009
Need AMSOIL?
post #7 of 15 Old 04-08-2008, 04:35 PM Thread Starter
NEp8ntballer
I'm just guessing that because the trackbar TRE is constantly under stress because of the weight of the vehicle that shaking it won't cause it to move unless i jack up the front end. It's the one that is oozing grease out of everywhere.
post #8 of 15 Old 04-23-2008, 09:07 AM
jake1
I have the exact same problem. A shop told me it was the backing plate rubbing against the rotor while turning. They said they bent it back into position and the noise was gone. But it came back just 2 days later. It's been like this for 2 months.
Gotten anywhere with yours?
jake1 is offline
post #9 of 15 Old 04-23-2008, 09:24 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Could also be the wheel hub bearings making the squeaking.
Jeep Sold! 02/2009
Need AMSOIL?
post #10 of 15 Old 04-23-2008, 09:30 AM
gomes512
1994 ZJ
The plate caused squeaks when turning? I was under the impression the plate turned with the rotors. In my mind that plate is useless anyways, the rotors cool down far better when it is removed.
Anyways, I would pump more grease into that joint that is oozing grease. Then take it for a quick ride and see if it cured the problem. If it did then you will know that joint was the culprit and you can have the grease boot changed.
gomes512 is offline
post #11 of 15 Old 04-23-2008, 07:50 PM Thread Starter
NEp8ntballer
it's either stopped or I've been able to completely ignore it. I think it mysteriously stopped because I've had the windows down lately to take advantage of the nice weather.
post #12 of 15 Old 04-28-2008, 10:15 AM
jake1
I neglected to mention mine is a XJ. 2 days ago it started making a creaking / grinding noise at the same time as the squeaking. This worried me enough to leave it in the shop while at work today. I brought it to a a shop that I like this time so I'm expecting the problem to be fixed for good.
jake1 is offline
post #13 of 15 Old 04-28-2008, 02:21 PM
jake1
Shop just called me.
Problem 1: The lower u-joint in the steering column is causing clunking. I already knew this. They tell me the part is on backorder but doesn't need to be replaced, I can just keep it lubed.
Problem 2: The front-left 4WD U-joint needs to be replaced - $170-$180.
I forgot to ask but I assume that Problem 2 is the squeaking problem since the squeaking noise came from the front left.
jake1 is offline
post #14 of 15 Old 04-28-2008, 05:58 PM Thread Starter
NEp8ntballer
sounds like it. I'm guessing that mine is the track bar sine I've experienced something that could probably best be described as death wobble. I drive over one certain bump with the front end and the whole truck starts shaking but stops after 4-5 shakes. It's pretty spectacular and nerve wracking. My squeak is back too. I think it stopped because moisture got into the grease boot since it has been at least once a week. I guess it finally dried out.
post #15 of 15 Old 04-28-2008, 07:08 PM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Yeah its possible. I had the same problem when I was stock height. You can try changing the trackbar bushings and greasing it or get a new one. When I did all my bushings up front (control arms, trackbar, sway bar, links) it made a big difference.
Jeep Sold! 02/2009
Need AMSOIL?
Squeak squeak goes the jeep.. -Joe- ZJ Grand Cherokee Forum 13 06-04-2013 07:30 PM
*squeak*squeak* 97DCZJ ZJ Grand Cherokee Forum 1 06-11-2009 09:27 AM
Squeak! Squeak! Squeak! WiLieR ZJ Grand Cherokee Forum 4 09-12-2007 08:40 AM
Squeak! Squeak! Squeak! KDH ZJ Grand Cherokee Forum 6 03-04-2007 11:44 PM
Squeak Daveeycrocket ZJ Grand Cherokee Forum 3 12-20-2004 12:47 PM
