94 ZJ fuel line leak help - JeepForum.com
post #1 of 3 Old 09-11-2010, 11:25 PM Thread Starter
calvin12
I just developed a leak in the hard fuel line on my 94 ZJ. its in the back line about a 1/4 inch past the end of the rubber line coming off the fuel rail. Is there any way to repair this or do I need to get a new hard line run? How far back does the hard line run before the next fitting? if the rubber hose to the fuel rail was 1/4 in longer. Would it be safe to use epoxy putty on it temporarily?
94 GC Limited, bone stock, I6, auto, Select-Trac.
calvin12 is offline
post #2 of 3 Old 09-11-2010, 11:37 PM
freakinheep89
it runs to the fuel filter. its a PITA to run a new one, the replacement is (as far as i have researched) only available from the dealer. My friend's kinked one day when working near it, and we had to replace it. The fuel seeping out will render JB weld useless, unless you remove it and clean and dry it. maybe try JB water weld? i used it on a fuel line on a neon once as a temp fix and it worked
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #3 of 3 Old 09-11-2010, 11:54 PM Thread Starter
calvin12
Thanks, I can get the line dry so JB should work if I cant find the water one. Just need a temp fix until I can get in it to get fixed.
calvin12 is offline
Transmission line leak?? Fix? brutusjeep WK Grand Cherokee & XK Commander Forum 13 03-19-2014 06:48 AM
fuel line leak at manifold Yardman Harry ZJ Grand Cherokee Forum 3 09-09-2012 11:29 AM
Help fuel leak on fuel rail 2002 4.0 jzhawk ZJ Grand Cherokee Forum 2 11-17-2009 01:56 PM
93 ZJ fuel leak where flex line meets solid line - Help Coletrickle ZJ Grand Cherokee Forum 5 08-13-2009 06:41 AM
Tranny cooler line leak alivenkickin28 ZJ Grand Cherokee Forum 6 02-02-2009 04:48 PM
