94 ZJ alarm/immobilizer question - JeepForum.com
post #1 of 6 Old 04-08-2008, 11:14 PM Thread Starter
GEEBEE
1994 ZJ
My ZJ has the factory alarm I am trying to figure out if the immobilizer is included in this option, how can i check it out ? need to know for insurance discount.
Thanks,
Cheers Jeff.
94' Grand Cherokee Limited 5.2 L, 250,000 kms
GEEBEE is offline
post #2 of 6 Old 04-10-2008, 02:30 PM Thread Starter
GEEBEE
1994 ZJ
Can anybody help me on this ??
Cheers Jeff.
GEEBEE is offline
post #3 of 6 Old 04-10-2008, 03:04 PM
Marcos
Yes, the factory alarm contains an immobilizer function. When the alarm arms, the module transmits an encrypted message to the engine computer saying "not ok to run". If the engine is started, it will shut off fuel a few seconds later, resulting in a start and stall condition.
When you disarm the alarm using the key in the lock cylinder or the remote, the alarm module transmits an "ok to run" signal to the engine computer.
Marcos is offline
post #4 of 6 Old 04-10-2008, 03:13 PM
LeroyJMC
1994 ZJ
Easy to check it too. Set the alarm while you're in the vehicle and let it sit for 30 seconds or so, then put the key in the ignition and try to start it without unarming the alarm. It should start up and then shut off within about 3 seconds or so.
2009 Red Rock JK Unlimited Rubi
2006 Scion xA
1999 WJ Limited Quadradrive V8
1997 Chevrolet Z71
1994 ZJ Laredo 4.0 - Sold
Thanks for the IR Remote Smokinbk.
LeroyJMC is offline
post #5 of 6 Old 04-11-2008, 10:45 AM Thread Starter
GEEBEE
1994 ZJ
Thanks for the information guy's, thats a great help an'
should save me a few $$ on the insurance
Cheers Jeff.
GEEBEE is offline
post #6 of 6 Old 07-18-2011, 01:01 AM
Telejoke
1994 WJ
While my mechanic and I were working on my Jeep the other day, the headlights were flashing -- but no horn sound. Didn't make much of it until the Jeep would not start. The mechanic found a place to test the fuel pump pressure and told me we need a new fuel pump.... cost about $200 plus labor.
Reading on this forum I discovered that the immobilizer can be "deactivated" using the key. Tried it on the lift gate and the Jeep started right up.
WORKAROUND: Don't use power locks or the key lock to lock your car. Manually lock all doors and the security alarm will be disabled. BAD NEWS: The security system actually has a purpose besides the seemingly universal malfunctions we read about here :-)
Telejoke is offline
Sentry Key Immobilizer problems PIAZ ZJ Grand Cherokee Forum 7 10-08-2014 08:27 PM
00 GC immobilizer/ alarm issue badcoupe ZJ Grand Cherokee Forum 1 01-26-2010 09:00 PM
Immobilizer/alarm problem Yankloverby4 ZJ Grand Cherokee Forum 4 08-27-2009 12:44 PM
Immobilizer/Sentry key problems PIAZ ZJ Grand Cherokee Forum 4 04-19-2008 04:01 PM
Won't start - immobilizer prob I think johnfrench ZJ Grand Cherokee Forum 0 09-09-2005 11:57 AM
