94 ZJ 5.2 gas problem? Please help. - JeepForum.com
post #1 of 9 Old 07-01-2013, 05:13 PM Thread Starter
AlpineStar94
Hey guys I'm looking for some help I've read other threads but I can't seem to find the answer I need. Anyways.. I was about to head to the gas station this morning and (ironically) I ran out of gas. Or so I thought.. It started up fine as normal but I gave it some gas and as soon as I did it sputtered and tried to die. I let off the pedal, and it smoothed back out. Hit the pedal again, and same thing happened. It seemed to be out of gas. So I got some gas in it from my red can and cranked it up (started fine) idled fine...so I tried to drive it around and it immediately stalled on me. So I got to looking through this forum and saw I should clean my idle sensor. I took it off and it looked almost brand new. I cleaned it anyways because there was a little carbon on it..put it back together and started it up. Idled fine for a second...I never gave it gas but after about 30 seconds it died on me again. So Back to the forum I went. Well after about 30 minutes or so I went back out and tried to crank it again. Cranked fine. I gave it some gas and the motor revved up fine and set back down to idle fine. So I popped the hood and took my air filter/hose off and noticed a sound that sounded like pressurized air. and it was coming from inside the tb. So I gave it some gas using the throttle under the hood and the noise got louder. I let off it, and it quieted down. Then my jeep started its rough idle and the air sound was really loud and it died. Sounded like a vacuum hose leak but all the ones I checked seemed fine. Now I have no idea what do. I recently cut off my muffler, not sure if that matters or not. And I'm only 18 so go easy on me I don't have much experience underneath a hood. Anyways...hopefully somebody can help me out
AlpineStar94 is offline
post #2 of 9 Old 07-01-2013, 05:30 PM Thread Starter
AlpineStar94
And I don't think it's my fuel pump because I'm getting plenty of pressure at the fuel rail. And my filter is brand new.
post #3 of 9 Old 07-01-2013, 06:15 PM
homerx
the first half of ur post kinda sounds like a throttle position sensor. the last half sounds like a vacuum leak, and it sounds like the plenum gasket to be more accurate. the 5.2 tend to eat them lol.
homerx is offline
post #4 of 9 Old 07-01-2013, 06:17 PM Thread Starter
AlpineStar94
Originally Posted by shdybrady19
hey mine doesnt have a shaft it just has a spring. Is this normal?
If I understand your question:
Uhmmmm.... NO!
The plunger is probably still in the hole...
Time for a new IAC
Never mind folks. Mine also just has a spring. I love this forum
post #5 of 9 Old 07-01-2013, 06:18 PM Thread Starter
AlpineStar94
What's a plenum gasket, in case a new IAC doesn't work? Is it expensive? Sorry I'm a noob...
post #6 of 9 Old 07-01-2013, 07:00 PM
Syncityj
It's attached to the blinker fluid reservoir, ha ha. Jk.
The plenum is between the throttle body and the air intake manifold. The gasket is on either side, I believe.
Sent from Hell
Syncityj is offline
post #7 of 9 Old 07-02-2013, 12:16 PM Thread Starter
AlpineStar94
Thanks syncityj. So I unplugged the electric clip for my IAC and it has been idling fine for about 10 minutes now. Is it safe to run with the disconnected until I can get a new IAC?
post #8 of 9 Old 07-02-2013, 12:16 PM Thread Starter
AlpineStar94
I have been running for a year with the IAC disconnected in my 94 ZJ. Runs great, no irradic idle ever. Disconnecting was the best test of my IAC. Normally starts in less than 1 sec. however on very cold Winter mornings it takes almost 2 sec. to start and idles a little sluggish for about 1/2 mile.
Got this off another thread idk how to do the quote box but anyways this is why I ask. But I want to be sure
post #9 of 9 Old 07-02-2013, 12:33 PM Thread Starter
AlpineStar94
And what happenes if I temporarily cut off my catelettic converter? my engine just overheated and the cat was red hot
