94 overhead console bulbs - JeepForum.com
post #1 of 5 Old 10-27-2011, 09:42 PM Thread Starter
stormer1092
1994 ZJ
What would be the bulb number on those square bulbs that clip in? They are the ones that have square holders that illuminate the step and us/metric buttons.
stormer1092 is offline
post #2 of 5 Old 10-28-2011, 12:16 AM
Smokey1r
I replaced both recently after one went out. After searching for my receipt they are GE 73 standard miniature lamp, they are of the plug in type and can be a pain in the butt to get out!!!!.
The little square brown bulb holders don't come off easily so disassemble the button assembly off the center console, un-clip the plastic cover and pull the bulbs out of the brown holders from the face side.
Smokey1r is offline
post #3 of 5 Old 10-28-2011, 08:59 AM Thread Starter
stormer1092
1994 ZJ
so the square things are just holders? They looked they are a pain it the arse to get out then. I broke the glass trying.
post #4 of 5 Old 10-28-2011, 03:21 PM
Smokey1r
Yes only bulb holders, leave them in!!! instead disassemble the cover off once you unscrew the button panel and use needle nose pliers to pull whats left of the bulb out, they will unplug with a simple pulling action providing you have a gentle grip on whats left and it don't break off, otherwise you'll be picking out whats left of the bulb remains. After that clean up, plug the replacement bulbs in and reassemble.
Smokey1r is offline
post #5 of 5 Old 02-11-2013, 02:34 PM
Higgins
First, check the little black socket the bulbs are plugged into. The connector tabs are SOLDERED to the back of the PC board, and sometime break loose due to vibration. If loose soldering should fix the problem.
If the bulbs do not want to come out, find a fine drill bit, and drill a SMALL hole in the back of the socket, very carefully. When that is acomplished, use a tooth pick or the but end of your drill bit, and caredfully push the bulb out of the socket!! No broken glass!!
Higgins is offline
overhead console bulbs JKDinSC ZJ Grand Cherokee Forum 0 07-18-2010 01:32 PM
Backlight Bulbs for overhead console oilcounter ZJ Grand Cherokee Forum 0 11-27-2008 10:39 AM
how do I replace the bulbs in the overhead consol? 02Lightning ZJ Grand Cherokee Forum 2 12-06-2006 04:33 PM
94 overhead console bulbs and power mirror ?'s calvin12 ZJ Grand Cherokee Forum 8 06-06-2005 01:05 PM
putting an overhead console in a non-overhead consoled gc gregmondro ZJ Grand Cherokee Forum 0 08-04-2004 02:31 PM
