94 JGC 4.0 trans shutters/slips - JeepForum.com
post #1 of 5 Old 07-06-2002, 04:28 AM Thread Starter
jeepcherokeev6
hey everyone
im posting this for my dad, who has a '94 JGC 4.0., Auto (42RE/A500)
when accelerating from a stop, the jeep shutters, unless starting off slowly and carefully, then its fine.
when it shifts into 2nd gear, it slips for a second, and then "grabs" and drives fine.
after its in 2nd gear, the tranny works just fine, and shifts normally through all gears.
if i take off slowly from a stop, the tranny also shifts just fine, and seems to engage normally.
we were thinking of just doing a rebuild, but if theres anything else we should try first, let me know.
we are going to do a complete fluid change, including torque converter, and replace the filter, and screen (ill post when this is done)
thanx for any help!
Dan, San Bernardino, California
'86 XJ, 2.8 V6 5 spd, 3" lift
"It may be a piece of sh**, but its MY piece of sh**!" -Me
jeepcherokeev6 is offline
post #2 of 5 Old 07-06-2002, 09:35 AM
JeepGuyRyan
If you haven't tried already, I'd do a transmission flush and filter change and try useing either Mecron V transmission fluid or something that is synthetic. That seemed to cure alot of transmission shudder and shifting problems I've had in both cars and trucks and I think it's worth a shot before you fork over the big $$$ for a rebuild.
good luck,
Ryan
-=Ryan=-
JeepGuyRyan is offline
post #3 of 5 Old 07-07-2002, 05:40 AM Thread Starter
jeepcherokeev6
from what ive read (meaning my dad read and told me), the only fluid that should be used is 7176 (or something like that). dextron, mercon, etc. are "grabbier" fluids, so the clutches inside the transmission will grab hard, making the computer want to let up, and clamp down, and so on, at something like 140 times a second, hence the shuttering. we plan to do a complete flush including torque converter, and use 7176. as i said, ill post when this is done and tell what happened.
also, if this doesnt work, we may need to have the transmission control module re-programmed, which can only be done by the dealer, as far as i know.
anyway, thanx for the reply, JeepGuyRyan
post #4 of 5 Old 07-09-2002, 10:14 PM
Intrepidjeep
Intrepidjeep's Avatar
ATF7176 or the ATF+3 or ATF+4 are all great for modern Chrysler transmissions.
I would NOT use Dexron Mercon at all.
-- Marcus
Cape Canaveral, Florida
2005 Jeep Grand Cherokee Laredo 4.7L
2005 Dodge Durango SLT 4.7L
Intrepidjeep is offline
post #5 of 5 Old 07-10-2002, 08:11 AM Thread Starter
jeepcherokeev6
well, its been pretty bad. on our cadillac, the brakes were actually missing parts (WTF?!). on my jeep (in my signature), i just finished rebuilding the rear end. but the JGC is the next project. i will hopefully be doing the flush of the fluid soon, and well see what happens. thanx for all the help guys!
Tranny slips, which trans do I have and error code diagnosis please. 248152 ZJ Grand Cherokee Forum 2 02-08-2010 09:58 PM
Trans. good cold, slips hot bird59 ZJ Grand Cherokee Forum 7 08-23-2009 10:12 PM
Jeep shutters in reverse while turning. Saskatoon2005 ZJ Grand Cherokee Forum 5 07-22-2009 08:06 PM
ENgine Shutters DTC 0201 lescher ZJ Grand Cherokee Forum 2 12-20-2008 03:52 PM
97 Auto Trans slips in 1st or 2nd + won't shift to 4th, TPS or bands? ERICH ZJ Grand Cherokee Forum 14 10-08-2004 06:56 AM
