94 Jeep Grand Cherokee - weird starting problem! - JeepForum.com
post #1 of 5 Old 03-16-2015, 12:59 PM Thread Starter
eseitz
Went to start my jeep the other day and made absolutely no sound when it started. I thought the battery was dead so i had a neighbor help me jump start it, and when we hooked it up the headlights and taillights starting blinking on and off. When I started the jeep, it turned over just fine and fired up, but then would die immediately right after that, with the lights still blinking on and off. When I took the jeep off the cables, the battery then died very quickly, so I decided to charge the battery overnight. When I tried starting it up the next day, it did the exact same thing with the firing up and then dieing again immediately (with head/tail light blinking). So it doesnt seem like its the battery, and probably not the alternator,what could it be? Is it perhaps some weird computer or fuse issue that is letting the car fire up, but then not transfer over to let the car realize it needs to keep going?
Any incite would be most appreciated!!
eseitz is offline
post #2 of 5 Old 03-16-2015, 01:09 PM
MrRoundel
Sounds like it could be a battery cable issue to me. If I were you, I'd remove the terminal clamps, clean the terminals and clamps, and put back on, making sure they are tight. That said, even if they are, it could be at the other end, at the starter, or perhaps at the alternator. You might also clean off your assorted grounds in the engine compartment. Do a forum search for ZeeJay1997 and the dirty dozen. Lots of good info there. Good luck.
MrRoundel is offline
post #3 of 5 Old 03-16-2015, 01:32 PM
6x-gpapa
It's your security system.
Due to the blinking lights, I'd say it's the factory security system. Also, the system is designed to allow the Jeep to start and then it kills the engine.
You'll need to reset the sec. sys. with your key fob. Make absolutely sure ALL doors are CLOSED-INCLUDING the HOOD and rear hatch!
If you have problems with the system, search this forum for the answers.
Good luck.
6x-gpapa is offline
post #4 of 5 Old 03-16-2015, 02:01 PM Thread Starter
eseitz
Oh my gosh! Thanks so much for the help. That was all it was, the security issue. Sometimes the security feature accidentally gets engaged and goes off when I access the Jeep. It must have not sounded the alarm, and just sapped the battery from the lights without me knowing about it, and then kept locking out the Jeep firing up all the way when trying to jump start it. Again, thank you so much for the assistance, you are a life saver!
eseitz is offline
post #5 of 5 Old 03-16-2015, 02:36 PM
travisyoung
1994 ZJ
To disengage the security all you have to do is put the key in one of the door locks or hatch and turn it like your unlocking the door and it turns off. No need to shut everything
travisyoung is offline
