94 jeep cherokee larado......6cyn - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 94 jeep cherokee larado......6cyn
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 10-14-2001, 07:53 PM   #1
debjohnlisa
truck just dies...then after afew minutes starts again....other then that runs great....help what can the problem ?????anybody know about recalls with this truck...
debjohnlisa is offline   Reply With Quote
Unread 10-16-2001, 04:02 PM   #2
redneckwithajeep
i have the same year and engine as u, with the same problem, someone told me a while back that the crankshaft position sensor was the likely cause. try replacing it or cleaning the contacts. any other suggestions?
'86 xj, 2.8, 3" lift
'94 zj, 4.0, stock (Sadly)
redneckwithajeep is offline   Reply With Quote
Unread 10-16-2001, 07:56 PM   #3
DMS
You might also want to check your battery. I had something similar happen with another car and it turned out the battery had a bad cell. Most shops can bench test the battery to see if that's the problem.
98 GCL 5.2l
DMS is offline   Reply With Quote
Unread 10-16-2001, 09:50 PM   #4
normdo
They had a lot of problems with crankshaft position sensors...that would be your best bet.
normdo is offline   Reply With Quote
Unread 10-29-2001, 05:11 PM   #5
debjohnlisa
the promblem was the was the fuel pump they say that there is many fuel pump replaced in that model and i was wondering if any body else needed to replace theirs....and did anyone know of recalls on this models
Unread 11-04-2001, 10:49 AM   #6
Dolphin
I have had two ZJ's over the past 8 years and had to replace the fuel pumps on both one @ 120k and the other @ 140k bothwere 94' models. this fuel pumps are expensive i paid $400 for both of them and that was the cheap aftermarket replacement. Good luck with this problem. The second time this happened to me i learned from the first incident that if you kick the bottom of the tank from the rear of the vehicle you can sometimes get the fuel pump to kick in long enough to get you of the road or back home. good luck.
Dolphin is offline   Reply With Quote
Unread 11-04-2001, 04:44 PM   #7
Kess
i also read that not only the crank sensor but the cam sensor, both cost up the wazoo, but the best of luck
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline   Reply With Quote
