94 Grand won't start no check engine light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 94 Grand won't start no check engine light
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 11-24-2005, 06:44 PM   #1
fflint_410
I have a 94 Grand Cherokee that won't start when you first turn on the ignition. The check engine light is not coming on for the 3 seconds that it shopuld and neither the fuel pump nor any other relay appears to be getting energized. You can crank it all you want and no joy.
If you wait with the key in the on position for 30 seconds or so the check engine will come on and the fuel pump and other relays engized and the car starts up and runs fine. You can then restart the car with no trouble.
Any ideas. Any help help would be appreciated.
fflint_410 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2005, 08:11 PM   #2
CajunWon
Have the Fuel Pump and ASD relays tested. They're in the PDC behind the battery.
Next check connector just over the fuel tank.
Next you're replacing the fuel pump for $90 or the entire assembly for ~$250.
94 ZJ w/95 4oh; NP231; LS w/3.73; headlight harness; Edelbrock IAS/Procomp ES9000 F/R; MSD w/Magnecor
CajunWon is offline   Reply With Quote Quick reply to this message
Unread 11-24-2005, 10:57 PM   #3
Woody
Retired back to Bowties
Woody's Avatar
1985
Won, hold up!
If the check engine light does not immediately illuminate when you turn on the key, the PCM is not getting going correctly. The ASD and fuel pump relays will not help if the computer isn't powering up. This is a write up that if followed should fix your problem for only a few dollars.
If you want to swap a few relays around that's fine, but this has the most likely chance of fixing your problem.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote Quick reply to this message
Unread 11-24-2005, 11:52 PM   #4
-Joe-
http://www.trendit.co.za/capacitor.htm
Heres an article on what to look for. Its a really common problem with computer electronics. Regardless of age, ive replaced them on motherboards only a year or two old. The only problem with just replacing bad caps are that once they reach a point of being bad they can cause other components to fail and replacing them wont fix the problem
The pcm should have a rubbery insulation on the entire board, but the caps are visable.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote Quick reply to this message
Unread 11-25-2005, 10:10 AM   #5
greasefingers
1994 ZJ
Here someone who just fixed this by replacing the PCM. His problems are just like yours.
http://www.jeepforum.com/forum/showt...=211787&page=1
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote Quick reply to this message
