94 Grand Cherokee Without front drive shaft - JeepForum.com
post #1 of 9 Old 04-22-2009, 06:17 PM Thread Starter
littlefdl
1994 ZJ
Hey, i just bought my 4.0 Cherokee and i have noticed that its missing the front drive shaft. Previous owner said the transfer case was bad and it makes a ''tapping'' noise when in 2wd. When in 4wd it's quiet as can be. Is it unsafe to drive in 4wd without the front driveshaft?
littlefdl is offline
post #2 of 9 Old 04-22-2009, 06:26 PM
micifus
Original GC'er
micifus's Avatar
well it's particularly bad for the AWD cases. Clearly there is something wrong with the TC so you will have to look into getting another any way. You basicly bought a 2WD GC
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #3 of 9 Old 04-22-2009, 06:31 PM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
since the PO said theres a tapping sound and you already have a 2wd option on the existing Tcase, I would start looking for a 242 in the local boneyard- it will probably be cheaper than fixing yours. While youre at it look for a front driveshaft. my .02
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
YJMCBoy is offline
post #4 of 9 Old 04-22-2009, 06:32 PM Thread Starter
littlefdl
1994 ZJ
I understand, i just wanted to make sure it wasn't straining the Transmission. It not a big deal as of now to me since i dont plan on taking it off-road. Its my DD
post #5 of 9 Old 04-22-2009, 09:04 PM
crashcraddock
How sure are you of this? Why would it hurt the TC, the output shaft would still be spinning. Plus you can turn sharper too.
crashcraddock is offline
post #6 of 9 Old 04-23-2009, 12:19 PM
Mickey_D
Because on the 249 transfer cases (AWD only) 1995 and previous the connection between the input shaft and output shafts was through a viscous coupler. This is what let you have power to both axles, yet still be able to turn without binding the drive train up.
In the older version (pre-1996) BOTH shafts were viscous coupled. It was determined that when the viscous coupler started wearing out it would lock the two shafts together. Upon further wear, it would actually allow a vehicle parked on a hill without the e-brake to roll away. My local 4X4 recycler had it happen 5 times in their parking lot over the years. In 1996 they changed the setup so there was only viscous coupling to the front and a hard connection to the rear.
Taking out the front driveshaft on the older version would let the front output spin free burning up the viscous coupler rather quickly. Picture a limited slip differential moving a vehicle with only one tire on the axle touching the ground. It will move, but eventually you're going to burn it up.
But in your case if you have a 2WD option on the selector plate it sounds like you have either a 231 or a 242 already. If you have the 4WD full time option you have the 242.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #7 of 9 Old 04-23-2009, 02:31 PM Thread Starter
littlefdl
1994 ZJ
Im sorry i didnt mention that my TC has 2WD, 4WD part time etc. No 4WD fulltime. Its a 94 GC 4.0. I drive it in 4WD Part time so the case doesn't make the tappin sound as it did in 2wd.
post #8 of 9 Old 04-23-2009, 04:44 PM
Mickey_D
Then you have a model 231 transfer case. The noise you are hearing is probably either a worn out chain or the front output bearing. Either that or the shifter linkage is slightly out of adjustment and one tooth on the gear is clicking.
________________
#4
Mickey_D is offline
post #9 of 9 Old 05-03-2009, 09:24 PM
Midnightluckey
Okay.. I think my VC is going out on my 95, and i am experiencing every one of the symptoms you guys are complaining about, but, when it clunks/lurches/jumps, my transfer case (and lever) like to jump into neutral.. Could this be something else? Or is that what you guys are talking about it being like your in 4wd all the time? And that it eventually will just jump all the way into low and stay there?
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
1995 Grand Cherokee Limited, Front Drive Shaft Q Birdee ZJ Grand Cherokee Forum 7 11-30-2013 05:48 PM
94 grand cherokee front drive shaft compatibility berkdog84 ZJ Grand Cherokee Forum 12 11-12-2013 06:30 PM
97 Grand Cherokee limited front drive shaft Blues DBALL ZJ Grand Cherokee Forum 24 12-15-2009 06:05 PM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 09:17 PM
97 Grand Cherokee Problem with front Drive shaft Carlthree ZJ Grand Cherokee Forum 0 07-07-2007 08:11 PM
