'94 Grand Cherokee Shifting Problem! Changed Trans still not shifting! - Page 4 - JeepForum.com
post #46 of 55 Old 04-14-2010, 09:06 AM
Bigwidge
okay, is that an easy fix? or is that something i should take to a repair shop to get fixed?
Bigwidge is offline
post #47 of 55 Old 04-29-2010, 12:29 PM Thread Starter
motoxracer1551
The gov pressure sensor was also bad on the used trans we got. Screen was completely clogged with metal on original trans, so we replaced those and now everything is ALMOST perfect. It shifts into 2nd fine but then shifts into 3rd almost 2 secs later. Is this normal? It seems to shift too fast.
Anyone looking to fix their transmission: CHECK FOR FAULT CODES FIRST!!!!!!
The pressure sensor and solenoids going bad are somewhat common. Also TCU's are known to go bad often as well.
Also the pressure sensor comes in 3 wire or 4 wire.
'01 Jeep GC I6 | '01 Jeep GC V8
Need your jeep repaired? No job to big or small! (516)761-1496
motoxracer1551 is offline
post #48 of 55 Old 12-08-2010, 03:37 AM
tylersjeep
1994 ZJ
over drive switch and rpm
okay guy i have a question about my rpm, when my cars at idle its stuck on 1 on the rpm gauge have trouble with acceleration, now me and a buddy of mine are tryingfigureO/D switch is on or off because my 94 grand cherokee v8 5.2 the swicth say off not on so where trying to figure out do i have to press it everytime i start the car to turn it off? when i push the over drive button in the car acceleration faster and it get 17 mile per gallon and when i dont press the botton in i get 9-10 mile per gallon so who made this botton it make no senes why would you have to turn the over drive off vs it being auto? why is there a botton that tells you to turn off vs on. im the only error code i get is 55 or 54 or a 52 not sure which one thought. please someone help me my tranny only has 100k i dont wont to blow it out.
tylersjeep is offline
post #49 of 55 Old 12-08-2010, 08:34 AM
YrbkMgr
From the service manual:
"The overdrive OFF (control) switch is located in the instrument panel. The switch is a momentary contact device that signals the PCM to toggle current status of the overdrive function. At key-on, overdrive operation is allowed. Pressing the switch once causes the overdrive OFF mode to be entered and the over-drive OFF switch lamp to be illuminated. Pressing the switch a second time causes normal overdrive operation to be restored and the overdrive lamp to be
turned off. The overdrive OFF mode defaults to ON after the ignition switch is cycled OFF and ON. The normal position for the control switch is the ON posi-tion. The switch must be in this position to energize the solenoid and allow a 3-4 upshift. The control switch indicator light illuminates only when the over-drive switch is turned to the OFF position, or when illuminated by the transmission control module."
2002 Grand Cherokee Laredo Straight 6, 4.0L
YrbkMgr is offline
post #50 of 55 Old 12-08-2010, 08:56 AM
tylersjeep
1994 ZJ
okay....let me get this right i have press the botton and turn the over drive off right? and how do fix the rpm being stuck at 1 in idle.
2010-12-08 10.45.22_Narragansett_Rhode Island_US.jpg   2010-12-08 10.45.38_Narragansett_Rhode Island_US.jpg
post #51 of 55 Old 12-08-2010, 11:25 AM
YrbkMgr
Wait, am I to understand that when your jeep is running, in park, it's idling at just under 1,000 rpm? And if so, what's the issue - you feel it is too high? If you can be more specific about what you're after, it'll help.
My understanding is that turning the O/D off, essentially prevents it from going into high gear and your gas mileage is worse on highway driving.
YrbkMgr is offline
post #52 of 55 Old 12-08-2010, 11:42 AM
tylersjeep
1994 ZJ
my jeep has trouble with acceleration with the over drive on so i press the O/D switch to turn it off and it acceleration faster and i get 17 mile per gallon. what im asking is why is there a switch to turn off and why is it not auto. when you press the O/D switch the light cames on and it shut the over drive off. from my understanding over drive on stop and go will kill you tranny and engine this why im ask why there is a off botton for the O/D does. to make it clear should A. drive and not turn the switch off or B. should a always press the O/D botton when ever im driving around town. the O/D is only for treps and long driving not for driving down the street to the store. and also my RPM is stuck at 1000 why i idle.
post #53 of 55 Old 12-09-2010, 10:02 AM
YrbkMgr
Over Drive doesn't kick in until about 40-50 mph, so in stop and go traffic, no, it won't burn out your transmission. I never turn mine off. Passenger vehicles don't have a switch - O/D is always on. If you're towing or on hilly terrain, you may want O/D off for more power.
So driving down the street to the store, you won't go into overdrive unless you hit 40-50 miles per hour.
As far as idle, what do you think the idle rpm's SHOULD be?
YrbkMgr is offline
post #54 of 55 Old 03-20-2014, 03:32 PM
mando69
94 jeep grand cherokee trans problem
its a 4.0 auto trans if i try to shift in from 1st to second it acts like its in neutral put it in odrive has to get to 3000 rpm to shift took it to a shop they said second gear is gone any help guys and thanks
mando69 is offline
post #55 of 55 Old 12-09-2014, 04:00 AM
Seedyrom
My shift solenoid went bad on a 94 grand cherokee and I'm seeing starts in second gear once warmed up. Did anyone who changed the solenoid experience blown seals due to higher pressure after changing? A friend suggested this could happen but I haven't seen this in tech manuals online.
I have a grand cherokee with 316,000 miles and I'm curious if anyone had issues within a few months?
Seedyrom is offline
Trans shifting problem protozee ZJ Grand Cherokee Forum 0 09-13-2008 01:55 PM
04 Grand Cherokee Shifting Problem off turns? sammysue04 ZJ Grand Cherokee Forum 6 05-21-2008 07:15 AM
'00 grand cherokee shifting problems silverbeetle74 ZJ Grand Cherokee Forum 5 09-23-2006 12:20 AM
My Grand Cherokee is not shifting properly?? toddplei ZJ Grand Cherokee Forum 3 02-21-2006 09:11 AM
2001 Grand Cherokee Shifting Problem MusicMan ZJ Grand Cherokee Forum 1 02-05-2006 02:03 PM
