'94 Grand Cherokee Shifting Problem! Changed Trans still not shifting! - Page 3 - JeepForum.com
post #31 of 55 Old 04-07-2010, 10:48 PM
baxy
gov solenoid just set gov pressure which in laymans terms is road speed input to the VB
the sensor just feeds back to the computer to verify that the solenoid did what it was told , the computer doesn't even use the sensor data to adjust the gov solenoid
baxy is offline
post #32 of 55 Old 04-09-2010, 11:32 AM Thread Starter
motoxracer1551
Bump!
Should I try another TCU? New solenoids? The wiring is all good, connector was cleaned and greased. I also tried clearing the TCU codes by taking the battery off, but they still showed up before even driving it.
'01 Jeep GC I6 | '01 Jeep GC V8
Need your jeep repaired? No job to big or small! (516)761-1496
motoxracer1551 is offline
post #33 of 55 Old 04-09-2010, 04:47 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
all of the solenoids going bad at once is extremely rare. look for a bad wire, fuse, relay, or the tcu.
ratmonkey is offline
post #34 of 55 Old 04-09-2010, 05:02 PM
YrbkMgr
How do you check for a bad relay?
2002 Grand Cherokee Laredo Straight 6, 4.0L
YrbkMgr is offline
post #35 of 55 Old 04-10-2010, 03:44 PM Thread Starter
motoxracer1551
I took the TCU out. Opened it up and the circuit board is all corroded. Now i can't seem to find one though. Nothing on ebay. If anyone has one or knows where i can get one LMK ASAP!!
TCU# 56027316
post #36 of 55 Old 04-12-2010, 10:10 AM
Bigwidge
I still have no idea what to do, when i do the key on off thing, i dont get a code, but my jeep still wont shift in the winter and some days in the summer, anyone know what could be causing this and maybe where i should start looking?
Bigwidge is offline
post #37 of 55 Old 04-12-2010, 11:26 AM
YrbkMgr
Do you have a Check Engine Light on? You might consider bringing it to Autozone and have them check any cods with their scanner. See what it turns up.
YrbkMgr is offline
post #38 of 55 Old 04-12-2010, 06:07 PM Thread Starter
motoxracer1551
changed the tcu. It works good now. But sometimes when I come to a complete stop it starts in 2nd gear. Then sometimes it will go to 1 after a second or just stay in 2nd. Also is there a way to make 1-2 shift happen a little later? It shifts and it feels like the motor is struggling because it shifted a little to early into 2nd.
post #39 of 55 Old 04-12-2010, 06:20 PM
JrMechanic
Adjust the TV cable.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #40 of 55 Old 04-12-2010, 09:18 PM Thread Starter
motoxracer1551
I tried adjusting it. The main problem I'm having now is sometimes it starts in 2nd from a dead stop. the 1-2 shift is good now though. I heard something about a check valve in the cooler lines for this problem. What should I do next?
post #41 of 55 Old 04-13-2010, 06:50 AM
greasefingers
greasefingers's Avatar
1994 ZJ
So where did you find another tcu?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #42 of 55 Old 04-13-2010, 11:22 AM Thread Starter
motoxracer1551
Got it at a local junkyard. Make sure you open it up quick though before you buy it and make sure the board is clean and nothing was leaking.
post #43 of 55 Old 04-13-2010, 12:45 PM
Bigwidge
I had it at a transmission shop about a year ago, and the guy put one of those computer scanner things, he didnt say of anything turning up, but he did mention something about that he would have to go more in depth with it some other time and that he thaught it might be somehow falling into the failsafe mode, any ideas on why the warm and cold weather can change how it shifts if its the failsafe? But thanks i will go to autozone and get them to test it out
Bigwidge is offline
post #44 of 55 Old 04-13-2010, 03:23 PM
Krziekracker
1994 ZJ
I had the same problem with my 94, since I replaced the TCM, I haven't had a problem with the tranny.......knock on wood lol.
Krziekracker is offline
post #45 of 55 Old 04-13-2010, 04:33 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
temp and gov pressure sensor is all one unit. one side or the other of that can fail. if the tranny thinks it is below a certain temp(0* i think) it will stay in limp mode till warm.
Trans shifting problem protozee ZJ Grand Cherokee Forum 0 09-13-2008 02:55 PM
04 Grand Cherokee Shifting Problem off turns? sammysue04 ZJ Grand Cherokee Forum 6 05-21-2008 08:15 AM
'00 grand cherokee shifting problems silverbeetle74 ZJ Grand Cherokee Forum 5 09-23-2006 01:20 AM
My Grand Cherokee is not shifting properly?? toddplei ZJ Grand Cherokee Forum 3 02-21-2006 10:11 AM
2001 Grand Cherokee Shifting Problem MusicMan ZJ Grand Cherokee Forum 1 02-05-2006 03:03 PM
