'94 Grand Cherokee Shifting Problem! Changed Trans still not shifting! - Page 2 - JeepForum.com
post #16 of 55 Old 04-06-2010, 11:28 AM Thread Starter
motoxracer1551
Going to check codes now.
'01 Jeep GC I6 | '01 Jeep GC V8
Need your jeep repaired? No job to big or small! (516)761-1496
motoxracer1551 is offline
post #17 of 55 Old 04-06-2010, 01:02 PM Thread Starter
motoxracer1551
Got codes 21, 22, 23, for the transmission.
21-Governor pressure solenoid output
22 Overdrive solenoid output
23-Converter clutch solenoid output
What do you think I should do?
post #18 of 55 Old 04-06-2010, 03:29 PM Thread Starter
motoxracer1551
TCU? Could all of the solenoids be bad in both transmissions, doesn't seem likely. But anythings possible i guess. So should I just try and find a used one from a junkyard or is there a way to test the tcu?
post #19 of 55 Old 04-07-2010, 04:08 AM
perfectcircle
I am assuming you've reset the computer after you installed your new tranny? If not, do it. Then drive it and check the codes again. These codes could be from the old tranny (and would have saved you a lot of money). If not and these are in fact still coming up than all you gotta do is change the sensors. The OD and TCC is one sensor together, and the g.press solenoid is another one but it's suggested to change the sensor and solenoid together. you can do this in your driveway with a little bit of time. Writeup: Replace Overdrive Solenoid + Gov Pressure Sensor/Solenoid 42re - MallCrawlin.com Forums
Before changing anything, check the plug on the outside of the transmission just behind the shift linkage. Make sure it's not cracked and all the prongs are straight and in tact.
perfectcircle is offline
post #20 of 55 Old 04-07-2010, 07:14 AM
Bigwidge
Mine says. Beep.....beep.beep.beep.beep.beep.....beep.beep.be ep.beep.beep....???
Bigwidge is offline
post #21 of 55 Old 04-07-2010, 11:12 AM Thread Starter
motoxracer1551
i think that would be code 55, so your not getting an error code.
post #22 of 55 Old 04-07-2010, 01:00 PM
Bigwidge
okay, the last repair shop i was at said something about it possibly being a lose wire somewhere, causing the failsafe to start, but i dont understand how a 'lose wire' can work in the summer, but not in the winter. My car shifts fine now that its getting warm, even if it does shift hard. But in the winter it seems to start out in 3rd gear or something.
Bigwidge is offline
post #23 of 55 Old 04-07-2010, 01:45 PM Thread Starter
motoxracer1551
I unplugged the TCU and tried driving manually. Won't go into first gear.
post #24 of 55 Old 04-07-2010, 02:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
that is correct operation with no power.
ratmonkey is offline
post #25 of 55 Old 04-07-2010, 08:39 PM
baxy
your losing power to the transmission somewhere intermittantly
relay, wiring , corrosion , fuse, connection at the battery or fuse box
to me it sounds like something is green somewhere
baxy is offline
post #26 of 55 Old 04-07-2010, 09:21 PM
JrMechanic
Originally Posted by ratmonkey View Post
Od light for tranny codes. Cel for engine codes.
Check your codes if you want help. You're in limp mode and the computer will tell you why if it didn't fail.
There is no limp mode on a 94.
To me, it sounds like the TCM doesn't know what the hell is going on. It's not getting accurate readings from either of the sensors. This tells me you have a bad connection at the transmission, or the TCM is bad.
Also with the TCM disconnected, it should start in 1st gear and shift though 3rd gear. The shifts will be extremely sloppy and inconsistent, however it should shift. If not I'd say you have a problem with the new transmission as well.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #27 of 55 Old 04-07-2010, 09:31 PM
Virmagicus
Virmagicus's Avatar
Originally Posted by greasefingers View Post
The TCM, transmission control module, will throw codes just like the Power Control Module will. I believe there are only separte TCMs on the years 1993 to 1995. To read the codes you count the number of times the Over Drive lamp lights. The Over Drive lamp is located on the over drive switch.
Extracting Fault Codes:
Without ever starting the engine Turn the ignition switch ON, OFF, ON, OFF, ON and observe the Over Drive lamp. The Over Drive lamp should begin to flash a series of codes. The flashes will be separated by short and long pauses. The long pauses separate the "ones" and "tens" positions, and each code from the next. A code 55 will be displayed at the end of the test.
Tranny codes for 1994 OD button LED
11 Engine RPM input
12 Output shaft sensor input
13 Vehicle speed input
14 Governor pressure sensor input
15 Throttle position sensor input
16 Transmission fluid temperature input
17 Overdrive override (control) switch input
18 System voltage
19 Internal fault in module
21 Governor pressure solenoid output
23 Converter clutch solenoid output
24 Overdrive override (control switch) lamp output
25 Internal fault in module
26 Governor pressure sensor offset drift
55 End of code transmission
For the V8 guys reading, this will only work on the 4.0's 93-95. No go on the 46RH.
Jeff
Virmagicus is offline
post #28 of 55 Old 04-07-2010, 09:32 PM
baxy
I never seen an RE go into first gear with no power to the trans
manually they only seem to ever get 2nd gear
there is too much govenor pressure with no power to the solenoid to allow the valve to move for a 1st start
also the TCM doesn't control line rise so the shifts can't get sloppy from disconnecting the trans or TCM
baxy is offline
post #29 of 55 Old 04-07-2010, 09:42 PM
JrMechanic
I may be mistaken about the 1st gear start. Thinking back to when I was trouble shooting my 42RE I could have sworn it started in 1st gear. Maybe not though.
And of course the TCM doesn't control line pressure, however the shifts will still be sloppy without input from the gov pressure sensor.
post #30 of 55 Old 04-07-2010, 09:45 PM
Virmagicus
Virmagicus's Avatar
Maybe the OP thinks it is getting to first when it is indeed second?
Jeff
Trans shifting problem protozee ZJ Grand Cherokee Forum 0 09-13-2008 01:55 PM
04 Grand Cherokee Shifting Problem off turns? sammysue04 ZJ Grand Cherokee Forum 6 05-21-2008 07:15 AM
'00 grand cherokee shifting problems silverbeetle74 ZJ Grand Cherokee Forum 5 09-23-2006 12:20 AM
My Grand Cherokee is not shifting properly?? toddplei ZJ Grand Cherokee Forum 3 02-21-2006 09:11 AM
2001 Grand Cherokee Shifting Problem MusicMan ZJ Grand Cherokee Forum 1 02-05-2006 02:03 PM
