94 grand cherokee Moog spring replacements - JeepForum.com
post #1 of 8 Old 11-12-2013, 10:34 AM Thread Starter
Iohannes
1994 ZJ
I have a 94 grand cherokee laredo, 4WD, I6 with no up country suspension. I need to replace the springs all around and would like to use Moog. I don't need a 2-3" lift.. just need to get it to ride like it used too. Every place online seems to have a different description (or lack there of) for Moog part numbers. I emailed moog and their response was:
CC721 = rear
CC780 = Frt RWD
CC782 = Frt 4WD
(sorry for sounding stupid) But i didnt know jeep made a grand cherokee that was only RWD. I've been reading through a lot of forums and i keep seeing CC782's referenced on the V8 models. Has anyone used CC721 and CC782 on an I6 and do they get you within normal height again?
Iohannes is offline
post #2 of 8 Old 11-12-2013, 10:57 AM
PolkaPower
Why do you need to replace the coils?
PolkaPower is online now
post #3 of 8 Old 11-12-2013, 12:29 PM
JasonStebbins
I was wondering the same thing. They usually out last the vehicle.
Are you replacing them because the ride is rough? Chances are that's from bad shocks, bad control arm bushings or bad isolators.
Poop
JasonStebbins is offline
post #4 of 8 Old 11-12-2013, 12:39 PM Thread Starter
Iohannes
1994 ZJ
The jeep never had shocks or springs replaced during its life. The shocks have been in need of replacement for a over a year. Over the last year I noticed that the jeep has "settled" more. The back is definitely now lower than the front. I don't understand either since i've only ever seen this in my old cherokee that had leaf springs. I was assuming if I replaced the springs, I would gain my original ride height.
Iohannes is offline
post #5 of 8 Old 11-12-2013, 12:48 PM Thread Starter
Iohannes
1994 ZJ
.. I also wanted to add. I already have the shocks so I was going to do all of it at the same time since I was already disconnecting everything.
Iohannes is offline
post #6 of 8 Old 11-12-2013, 01:06 PM
JasonStebbins
How many miles on the Jeep? They springs could indeed be sagging, but it's weird that the rear is sagging. Do you do a lot of towing/hauling?
Check out the rubber isolators that sit on top of the springs. Mine were so crushed and rotted that the spring had pushed all the way through them, causing rake in the front.
You can replace the shocks as it sits, no jacking up/removing anything else is required.
Poop
post #7 of 8 Old 11-12-2013, 01:33 PM Thread Starter
Iohannes
1994 ZJ
Thanks for the responses. It has 185k miles. I do some light towing a couple of times a year. The rear spring isolators do look rotted and crushed. The tops of the rear springs also appear to have a good amount of rust (compared to the front).
Iohannes is offline
post #8 of 8 Old 11-12-2013, 04:26 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I totally replaced the front and rear suspension on the 98 2WD{ yes we exist,lol} except for 4 things.....the springs. So I'm going with what Polka and Jason said. I did replace all the isolators too.
Originally Posted by HighLonesome
coralman is offline
