94 Grand Cherokee Limited starting/alarm issues - JeepForum.com
post #1 of 3 Old 07-02-2013, 08:08 PM Thread Starter
Lostone01
I have an issue with my 1994 Grand Cherokee Limited. I recently had oil change, tune-up and alignment done to my Jeep and now am having issues with it starting and the alarm going off. I don't think the recent work has anything to do with it but am trying to give all info. I went out today and it would not start, so I replaced the battery with a new on. Same problem. It acts like the battery is dead, won't start, won't turn over and the alarm goes off. The headlights/flashers were flashing and now just the flashers. They do go off when I lock/unlock the door (I do not have a key fob...was never given one when I bought this a year ago).
Anything I do is setting off the alarm...I disconnected the battery and re-connect it, the alarm went off...I turned on headlights (which are not coming on now) and the alarm went off....when I turn the key just to accessory, the alarm goes off...I do still have door buzzer and under hood lights though...lol...but everything else is acting like a dead battery
If I disconnect the alarm on the rear tailgate and loop the wires, will that disable the alarm and allow the Jeep to start?
Lostone01 is offline
post #2 of 3 Old 07-03-2013, 07:48 PM Thread Starter
Lostone01
I disabled the alarm at the tailgate and replaced the battery with a new one but still nothing. It still acts like a dead battery. I get a couple of clicks out of the starter and then nothing. Any ideas at all?
post #3 of 3 Old 07-03-2013, 09:48 PM
dellis
2005 WK
If your battery is good, then I'm suspecting either your battery connection or your starter. Double check the connection to your battery - you may not have it properly tightened. The clicking description, however, makes me think your starter is suspect. A starter is easy to remove and test at your local parts store. Probably coated in lots of oil.
dellis is offline
