94 Grand Cherokee audio wiring? - JeepForum.com
post #1 of 7 Old 01-09-2011, 03:25 PM Thread Starter
panathemaju
1994 XJ Cherokee
Hey all,
I just installed a new receiver in my Jeep, and my next ideal step is replacing the back door speakers since they're nothing but distortion. I'm a little confused on the factory wiring setup, though. It has the Infinity Audio setup, so it has a 180W 6-channel junky amp under the seat. My question is, since I replaced the head unit, am I still wired through the amp, and if so, how hard is it going to be to change?
If anybody knows a source for an audio wiring diagram, or just something that can expain the factory setup, it would be awesome. Thanks!
panathemaju is offline
post #2 of 7 Old 01-09-2011, 04:51 PM
jPaul92
the12volt.com always has dependable diagrams.
jPaul92 is offline
post #3 of 7 Old 01-10-2011, 09:41 PM Thread Starter
panathemaju
1994 XJ Cherokee
Dependable, but not specific enough...
I wish they had one for the Limited edition with Infinity Audio... the whole system is component speakers, and I can't find anything telling me how the amp is wired at all.
post #4 of 7 Old 01-12-2011, 05:25 PM
gomes512
1994 ZJ
Forgot where this was from...
gomes512 is offline
post #5 of 7 Old 01-12-2011, 06:03 PM
Canyon411
The factory infinity headunit has speaker-level output rather than rca (line-level) connections. These are run to the infinity amplifier's speaker-level inputs. Then you have 6 channels of audio. Front doors & tweeters, rear doors and rear hatch. Should be strait forward replacing the hatch speakers if they are the ones that are blown and having it sound good again.
Canyon411 is offline
post #6 of 7 Old 01-12-2011, 07:40 PM
bowstryder
bottom line is that you are using an amplified signal from the new head unit (which should normally go straight to the speakers) to the factory amp. This doesn't mean you are sending twice the power out but are intensifying the signal which is put out to the speakers via the factory set up. My suggestion is to rewire the sound system directly from the new receiver and enjoy better sounding music. Then you can remove the factory amp and have more room for other goodies under the rear seat. hth
bowstryder is offline
post #7 of 7 Old 01-12-2011, 08:46 PM
Canyon411
If it were me, I would hook the new headunit into the existing connections in the dash. Get a conversion harness so you dont have to chop the factory wiring. While you have the dash apart, I would also take the time to run a few pairs of rca audio cords and an 18 gauge wire (possibly used for a remote power wire in the future) from the dash to under the rear seat and bundle them neatly for future use. The infinity amplifer will do a decent job of adding to what your new headunit puts out. If you decide to run aftermarket amps later down the road, you can revise the wiring under the seat to connect with your new amps.
audio components , speakers
'08 Grand Cherokee - MyGig issue - No audio Morbeas WK Grand Cherokee & XK Commander Forum 12 07-16-2011 01:54 PM
BOSS AUDIO BV8975B In-Dash DVD Stereo For 2005 Jeep Grand Cherokee Limited javi4rmla WK Grand Cherokee & XK Commander Forum 1 08-29-2010 08:32 PM
99 grand cherokee audio bwtucker83 ZJ Grand Cherokee Forum 2 09-30-2006 02:37 PM
Grand Cherokee audio... jarheadglidden ZJ Grand Cherokee Forum 14 04-01-2005 08:47 PM
JL Audio 12w7 in Jeep Grand Cherokee PublicEnemy ZJ Grand Cherokee Forum 1 04-29-2003 07:12 AM
