94, Grand char limited, Backfire/no power - JeepForum.com
post #1 of 4 Old 02-08-2008, 01:18 AM Thread Starter
jeeprguy
Looking at picking up a 94 Grand Charokee limited. Problem with jeep is:
Backfiring and lose of power.
I have not had a chance to go check it out yet but hoping I can get some ideas on what to check.
Been done:
Plugs/wires/O2 sensor/timing belt was checked and said to be good.
Wondering if plug wires could be reversed or leaky intake?
Does any one have a small diagram of how the plug wires route to each cylinder?
Any ideas what to check would be most helpfull
Thanks
Rich
jeeprguy is offline
post #2 of 4 Old 02-08-2008, 05:40 AM
Turbonut
Doesn't have a timing belt, but a timing chain. The firing order is the standard 1-8-4-3-6-5-7-2. 1 being left front from driver's seat.
Check distributor cap and rotor, rotation is clockwise.
Compression test.
Clogged exhaust-converter
Turbonut is offline
post #3 of 4 Old 02-08-2008, 06:45 AM
Ruffturn
If it's a 4 liter, the #1 plug wire boot easily gets torn if someone isn't careful when removing it (don't ask me how i know that). If it's torn, it'll arc to ground and cause a miss. Something else to look at would be ignition coil output, but you may have a hard time starting it if the output voltage from the coil was too low. It would certainly cause your other symptoms though.
Hope that helps.
Ruffturn is offline
post #4 of 4 Old 02-08-2008, 09:10 AM Thread Starter
jeeprguy
Thanks for info. Any ideas what the output volatge should be from the ignition coil? Thanks for firing order. Do you have diagram of how the wires position on the dist? What is accpetable chain play for timing? I am assuming this truck has OBD or OBDII?
jeeprguy is offline
Char residue on intake manifold and loose evap hose compcrasher86 ZJ Grand Cherokee Forum 22 03-01-2009 12:45 PM
Grand VS Limited Bodfish Vic ZJ Grand Cherokee Forum 5 08-03-2007 06:15 PM
power drain in 5.9 limited robvb525 ZJ Grand Cherokee Forum 3 07-06-2006 01:06 PM
very important horse power of 2000 grand cherokee limited v8 kulltogi WJ Grand Cherokee Forum 1 12-25-2002 05:09 PM
Rear hatch for a 98 ZJ Char gold 2 turk ZJ Grand Cherokee Forum 1 10-14-2002 04:43 PM
