94 gc limited slip differential chatter noise - JeepForum.com
post #1 of 4 Old 06-28-2003, 03:38 PM Thread Starter
amcars
My car is chattering very strongly when turning corners. It doesn't occur when cold but after driving about 20 miles or so its there.
If you have to park to a tight place and turn wheels all the way right or left you can hear chattering noise and it feels like rear wheels have hard time spinning.
I have changed new oil and even added some additive. I think it was ment for GM vehicles. Should I use some Mopar stuff or what to get rid of this.
amcars is offline
post #2 of 4 Old 06-28-2003, 05:39 PM
boing
What do you have in your 94 is it a V8 or I6 if its a V8 with the 249 TC it sounds like the viscious coupling is starting to crap out on you.
Boing
boing is offline
post #3 of 4 Old 06-29-2003, 03:45 AM Thread Starter
amcars
I was thinking that it could be some problem with the limited slip differential clutch pack?
If it is this TC coupling problem (the car is L6 with 249, alltime 4wd) how will this fault proceed? More noise even driving straight? No more driving wheel or what?
amcars is offline
post #4 of 4 Old 07-01-2003, 11:55 AM
anthonyh75
I have a NP 249 transfer case for sale. It is in good condition and is in my jeep running now. I thought it was my Viccious coupling so I got a new Transfer Case and found out it was actually the OD gear set in my Transmission that is making the noise. Make me an offer on the Transfer case. I have found that the Vissious Couplers are about 400 alone. I did see someone selling one for cheaper on here you may want to look on here.
1998 5.9L Limited, 99 TL 1000s, 1995 Stingray 586zp
anthonyh75 is offline
03 wj how do i know if i have limited slip? ronsaun ZJ Grand Cherokee Forum 10 10-18-2009 11:52 AM
Limited Slip Differential need new clutch pack lordMylanta ZJ Grand Cherokee Forum 8 08-23-2009 04:46 PM
Limited slip differential CRD Owner WK Grand Cherokee & XK Commander Forum 13 09-10-2007 10:29 PM
Limited Slip 99-GC ZJ Grand Cherokee Forum 2 03-16-2007 05:28 PM
Do i have limited slip bownw ZJ Grand Cherokee Forum 3 03-03-2005 04:13 AM
