94 GC 5.2l Runs then sputters and dies - JeepForum.com
post #1 of 3 Old 12-23-2003, 07:20 PM Thread Starter
braell
braell's Avatar
94 GC 5.2l
She will start fine when cold, then sometimes after making say a grocery run after leaving the store the idle will start fluctuating and it will die....
Before all of this I've recently replaced the fuel pump(& filter) and oxygen sensor.
This ones got me stumped; once when it happened I had my meter with me and found there was about +7vdc on the return/negative side (goes back to PCM) on both the throttle pos. & MAP sensors even with the connectors disconnected from these sensors. The only sensors that are connected on this (PCM) circuit are the TPS, MAP, O2 Sen and I think the oil pressure or manifold temp.
Somehow temp related though...?? HELP!
braell is offline
post #2 of 3 Old 12-25-2003, 08:28 PM
Swamp Boy
Swamp Boy's Avatar
Dont know but mine is doing something similar.. On a cold day it will not idle
I have to hold the throttle down till it warms up then it runs fine..
I dont know if there is a choke or something that could go bad.. I am trying to figure this out now..
If I find something out I will let you know..
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 3 Old 12-27-2003, 06:41 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I had a similar problem about two years ago. I replaced the ignition coil, distributor, wires and sparkplugs and it went away. It would idle no problem then, when I tried to accelerate away, it would sputter and stammer until it finally caught. NOt fun on the entrance ramp on the interstate.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
ZJ randomly dies - runs fine otherwise jish ZJ Grand Cherokee Forum 11 01-23-2010 10:38 PM
Cooling Fan Runs Until Battery Dies Please Help!!!! HEAVYZZZZZZZZ ZJ Grand Cherokee Forum 3 05-05-2008 09:32 PM
HELP please - Jeep runs good, then dies in gear jamier095 ZJ Grand Cherokee Forum 0 02-28-2008 02:07 PM
99 Wj intermittent runs and dies..semi urgent dungbeetle ZJ Grand Cherokee Forum 9 11-26-2006 06:55 AM
Jeep dies or sputters cody11ca ZJ Grand Cherokee Forum 2 08-25-2006 09:41 AM
