94 GC 5.2 Rough idle when cold. - JeepForum.com
post #1 of 4 Old 11-08-2009, 02:31 PM Thread Starter
smoulding
My 94 GC with the 5.2L idles rough when cold. It revs a little high, then low, and rough. After it warms up for about a minute it runs fine, will run good. Let it sit for a while, start it up, and it will do it again only for about a minute, then all will be fine.
It just started doing that.
I had recently replaced the fuel pump and filter.
Ideas?
Thanks.
smoulding is offline
post #2 of 4 Old 11-08-2009, 06:23 PM
takethisride
i have a 96 with a 5.2L in it, and unfortunately it does the same. i have no idea what it is. and it just started when it started to get cold
96 ZJ 5.2L 4x4, 4.5" Lift, NP231 swap, Beefed Custom Cline front DS, 33" Goodyear Wrangler Duratracs, 15x10 RCX wheels, JKS front and Rear track-bars, Flowmaster 40series, Cobra CB radio, Optima Yellow Top, Snorkel, Rough Country winch mount, Super Winch TS9500, cut fenders, Red Jeep Club #572, Built Not Bought #279
takethisride is offline
post #3 of 4 Old 11-08-2009, 10:49 PM
bobotech
Tag.
My buddy has a 94GC with the 5.2 that does the same weird surging. I'm wondering if its a TPS but that would be all the time, not just when its cold.
bobotech is offline
post #4 of 4 Old 11-09-2009, 12:37 AM
cologc46
cologc46's Avatar
First thing most people recommend for rough idle is to clean the Idle Air Control. The IAC is on the throttle body, it is easy to disassemble and clean. Someone posted step by step, if you search it is easy to find. Or, just click here: http://www.jeepforum.com/forum/f13/h...-valve-756934/
cologc46 is offline
Intermittent rough idle cold and hot. bjl95mustang ZJ Grand Cherokee Forum 3 10-08-2009 04:55 PM
03 WJ 4.0 Rough idle / cold knock hammertech ZJ Grand Cherokee Forum 9 11-26-2008 12:48 PM
rough idle when cold ? jeepunlimited ZJ Grand Cherokee Forum 1 07-26-2007 08:17 PM
Update: I-6 rough idle when cold VA_Jeepster ZJ Grand Cherokee Forum 0 09-09-2003 09:50 AM
Rough idle at cold start --- 01' Grand with I-6 VA_Jeepster WJ Grand Cherokee Forum 7 09-02-2003 05:07 PM
