94 5.2 code 21, and 27won't stay running - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 94 5.2 code 21, and 27won't stay running
Winter & Offroad TiresIRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 01-10-2015, 03:14 PM   #1
Jridgley
Hello all, I'm having problems. My engine starts fine, then will die about after 30 seconds. About a day ago my problem originated with it dropping rpms at lower speeds, now today it will drop rpms and die in drive or in any gear. I cleaned the iac and didn't really do anything m I'm getting codes 21,and 27. I've cleaned all of my injectors and no luck. What's going on!
Jridgley is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 03:38 PM   #2
Jridgley
So, now it's only doing it in gear, it'll drop from 3000 all the way to idle. I just had a transmission rebuild. Could this be the torque converter
Unread 01-10-2015, 08:49 PM   #3
6x-gpapa
According to the manual-T/C 21 is "problem with O2 sensor circuit, sensor voltage to computer not fluctuating." T/C 27 is "one of the injector control circuit output drivers does not respond properly to the control signal. Check the circuits." What spark plugs are you running? Use Champion RC12YC w/.035" gap.
6x-gpapa is offline   Reply With Quote Quick reply to this message
