'94 4.0L won't fire til you touch brake pedal & wierd stuff. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > '94 4.0L won't fire til you touch brake pedal & wierd stuff.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 09-06-2013, 08:32 PM   #1
Maine1994ZJ
Okay, so I thought my wife was crazy, but her '94 4.0L ZJ will turn over fine but won't fire until you push the brake pedal..... Strangest thing I've ever encountered....
Well except the strange sound the buzzer makes and the idiot lights flickering wildly when you shut the key off......
I'm thinking I need to take the dash apart and check connectors and grounds?
Unless someone has experienced these particular quirks before, and can point me in the right direction? Possibly?
I couldn't find anything in the search or FAQs.....
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline   Reply With Quote Quick reply to this message
Unread 09-09-2013, 06:50 PM   #2
Maine1994ZJ
Bump!
Unread 09-09-2013, 07:23 PM   #3
ZeeJay1997
pull the connector off the brake switch on the pedal. then see if it will crank.
if it does check each contact on the harness to ground.
do your brake light work?
no diagram so not much help
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 09-09-2013, 07:58 PM   #4
Maine1994ZJ
Yes, brake lights work correctly. Along with cruise control & torque convertor lockup.
Will disconnect and check it out in the mernin'.
Thanks! It's a place to start!!!
Unread 09-19-2013, 11:01 AM   #5
Maine1994ZJ
Problem solved!
Once I figured it out I was completely shocked...
The screw that the ground for the remote starter went under had come lose, making for a half-assed ground.
So I put a larger diameter screw in the hole and cranked it down tight, making sure the ground wire was firmly in place.
I knew grounds would cause gremlins, but that was NUTS!!!
No more hard starts/no starts without touching the brake pedal, no more flashing dash lights and dieseling when shut off..... because of ONE loose wire...
