93zj AC issue - JeepForum.com
post #1 of 3 Old 04-10-2013, 08:31 PM Thread Starter
TRDRacer
93zj AC issue
Hello, I am new to the board and new to jeeps. I am mechanically inclined and do fix most of my own cars. So with that said I have been slowly Fixing up my jeep. I have already fixed the trans, transfer case, rear diff, brakes, fluids, valve cover gasket, plugs and wires. I am now trying to tackle the AC. I took a gauge to it to see if there was any pressure and any freeon in it. It was low and the freon was at zero mark. I tried to run the car and flip the AC system on to see if all is working. The clutch does not enguage as I believe if there is no freeon then it won't have any pressure to spin up the compressor. So I checked all the fuses and relay and all are ok. So to test out the clutch I unplugged the connector and plugged a piece of wire to each end of the plug making a C clip with the wire. The clutch turned on and was working well with no noise issue. So I proceeded to get a can of 134a and fill it just to see if I could find any leaks. I charged the system and proceeded to let it run for about 5 min but the clutch will not turn on unless I unplug it and put in the C clip of wire. Then it runs. So is this a wiring issue under the dash to the canister or what?
TRDRacer is offline
post #2 of 3 Old 04-11-2013, 03:06 PM Thread Starter
TRDRacer
Fixed the issue. All good.
TRDRacer is offline
post #3 of 3 Old 05-17-2013, 04:27 PM
Guest
1994 ZJ
what was the problem after all? how did you fix it?
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxzj94x4L is offline
