93gc Problems!!!!! - JeepForum.com
post #1 of 3 Old 09-09-2002, 11:07 AM Thread Starter
troutslayer
93gc Problems!!!!!
OK,
I replaced the security module thinking that would be the end of my woes,but it isn't.I can turn the key for like 5 seconds and then it goes into a funk.I turn the key to off and then immediately try to start it again and then it will statrt right away.If that isn't enough,I adjusted the idle along with replacing the plugs,wires,air cleaner,throttle body was cleaned,fuel filter,fuel pump was checked.I have bad hesitation at stop signs and stop lights.When I go to accelerate from a stop,it wants to die.I have to keep it in neutral to keep it running.I performed the OBD and I got "5" check engine lights a pause and then "5" more,I guess for a code of "55".Does anyone here have any idea what is up with this thing??? It is driving me nucking futs. Please help me
troutslayer is offline
post #2 of 3 Old 09-09-2002, 04:03 PM
moabster
moabster's Avatar
2011 WK
Hi Troutslayer,
The 55 code just means "end of code", so the OBD did not detect any problems.
From reading your past posts it sounds like you have tried all of the obvious things. It may be cheaper to have a dealer or auto shop you trust look at it and a least give you an estimate for what it will cost to fix it.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #3 of 3 Old 09-09-2002, 04:45 PM Thread Starter
troutslayer
I guess the next order of buisness is to replace the crank postion sensor,o2 sensor,cat converter,fuel injectors,ignition coil.If this doesn't work,I'm going to send it off a cliff.........
Removing oil pan/ 93GC oucrazy ZJ Grand Cherokee Forum 3 04-13-2006 01:34 PM
Brakes "93GC oucrazy ZJ Grand Cherokee Forum 9 08-19-2005 02:35 PM
93GC I6 AC Compressor DaffyDuck ZJ Grand Cherokee Forum 1 08-18-2003 01:52 AM
93GC Ltd Info Center display keeps resetting iroc22 ZJ Grand Cherokee Forum 1 08-11-2002 07:43 PM
PLEASE HELP! Starting problems 93gc ltd troutslayer ZJ Grand Cherokee Forum 10 08-04-2002 08:48 PM
