93 ZJ will stay in to part time 4wd, and 4wd low, but not Full time 4wd - JeepForum.com
post #1 of 5 Old 10-31-2010, 05:06 PM Thread Starter
erichian
I this a transfer case issue, or something simple? I have a 93 ZJ with a 4.0, I don't know if its command or select trac, but it will not stay in full time 4wd. Part time works fine as does 4wd lo. If I go into full time its fine at first, but after I come to a full stop it feels like the jeep is now in neutral, and the jeep won't move until I put the transfer case in a new gear.
No clue what could cause this. I just purchased the jeep, and the previous drove it for month with the front drive shaft removed. He reinstalled it at my request before the purchase. I don't know if that could be the cause or not.
I didn't notice this on the test drive but when I came to a full stop I probably just put it into 4wd lo.
Last edited by erichian; 11-02-2010 at 08:30 PM. Reason: I thought may be I said something wrong considering no responses.
erichian is offline
post #2 of 5 Old 11-11-2013, 03:45 PM
stevo44544
I'm having a similar issue, I pull mine to 4wd full time and it seems to be in part time. My indicator lights are dead so I can't tell what gear the transfer case is in. Just by feel. So when I give it throttle though a turn in 4wd full time the tires jump, indicating part time... I only posted here because we may have a similar problem.
stevo44544 is offline
post #3 of 5 Old 11-11-2013, 05:12 PM
shaban
How about 2wd, does it work? If your shifter linkage is misaligned you may actually be in 4wd full time when the shifter is all way forward.
PS - You can check it by jacking up the front wheel and trying to turn it. If it doesnt turn in 2wd that would mean its in 4wd.
Also, which tcase you've got, 242 or 249? It's 249 if you have "4HI, NEUTRAL, 4LO" on shifter, and 242 if its "2WD, 4FT, 4PT, N, 4LO"
shaban is offline
post #4 of 5 Old 11-11-2013, 05:36 PM
JasonStebbins
You have the 242 selec-Trac transfer case. Try adjusting the linkage underneath the Jeep. It may need a new bushing. You have to be in neutral coasting slightly to engage 4Lo. The front shaft was probably removed because the front differential is bad or he thought it would improve MPGs.
Poop
JasonStebbins is offline
post #5 of 5 Old 06-26-2014, 07:49 PM
bradmorrison
I have a 96 zj that im having the same issue with the 4 full time not staying engaged, 4 part time and 4 low work good and 2 wheel is also working.
bradmorrison is offline
Part time and Full Time 4WD Difference Igorot_Jeeper ZJ Grand Cherokee Forum 8 12-16-2014 10:42 AM
Part Time or Full Time? cweb ZJ Grand Cherokee Forum 2 02-19-2008 08:24 AM
Smoking Diffs? Part Time/Full Time? azcoyote ZJ Grand Cherokee Forum 30 04-01-2007 07:29 PM
GC Part-Time and Full-Time 4x4? What's the difference? rockon1202 ZJ Grand Cherokee Forum 14 03-04-2005 03:19 PM
Full time 4wd to part time conversion? yourNME13 ZJ Grand Cherokee Forum 6 04-20-2002 11:49 AM
