93 zj starting problem - Page 2 - JeepForum.com
post #16 of 23 Old 07-07-2011, 08:32 PM Thread Starter
jetboy287
It doesn't seem like it's that hard of a fix. I have a little exp working with a soldiering iron and working on something with parts that large sounds like a breeze to me. Much better then micro soldiering on a mother board. If I can source the caps then I may be okay. I'll have to swing by the shack when I get off work in the morning. Thanks all. I will let you know how it turns out as soon as I get it done
jetboy287 is offline
post #17 of 23 Old 07-07-2011, 10:19 PM
Oldfrog
2007 WK
Radio shack has the caps. Make sure you get the 35W or better. I cant remember if they are 27 mf or 17mf or a few of both. ( and not trying to be a smart azz, but they are electrolytics, so they have a polarity and only go in one way. Pay attention to the old ones b4 you remove them.)
Personally, I'd rather obtain them from an electronics supply house, instead of R-shack.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #18 of 23 Old 07-07-2011, 10:31 PM Thread Starter
jetboy287
Would that I could but radio shack is about the only place around here that sells any kinda replacement parts I'm kinda out in the middle of nowhere
post #19 of 23 Old 07-07-2011, 10:38 PM
JeepFreak1982
You can always order higher quality caps off the internet.
JeepFreak1982 is offline
post #20 of 23 Old 07-10-2011, 10:08 PM Thread Starter
jetboy287
So just a little update. I replaced the burnt out cap and she runs and starts like new thank you all for the help the hardest part was getting all the gel off so I could get to the cap. I'll let y'all know if I have any other trouble out of it
post #21 of 23 Old 07-11-2011, 07:41 PM
Oldfrog
2007 WK
<Applause>
I hope it stays that way !
Oldfrog is offline
post #22 of 23 Old 07-11-2011, 09:36 PM Thread Starter
jetboy287
Yeah. You and me both
post #23 of 23 Old 07-11-2011, 09:48 PM
mike_breaker_5
Originally Posted by jetboy287 View Post
It's possible that it's the cps but does that control the fuel pump?? I thought that it just worked the firing order. I really don't know when it had a tune up last but the plugs and wires look brand new I've only had it about a month and it's just started giving me grief. What does the auto shutdown do? What sensors does it look at?
yes if the pcm doesn't get signal from the CPS it will not engage the circuit for the coil of fuel pump. this is how the pcm keeps the engine from getting flooded with gasoline.
i know this problem has been solved but since i'm having this exact problem i will be opening up my PCM this coming weekend (my yj has a 93 zj 5.2), so this is also my way to sub for future reference.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
