93 ZJ with rear diff/axle probs - JeepForum.com
post #1 of 12 Old 02-06-2013, 02:19 PM Thread Starter
NCjeepgirl83
Hey all,
My family has a 93 ZJ that's been in our family since new. It has sentimental value to our family and we have discovered that it has a bad pinion bearing in the rear axle assembly. What would you all suggest we do that would be a cheaper alternative than to pay $5k for a new one? The mechanic at our local Firestone says that it's a very common problem with Jeeps this age...
Should we go to the dealer? The Firestone guy said it would cost $2-3,000 to repair the existing axle, and we'd prefer not to have to pay more than the car's worth, if that makes sense.
What would you do in our shoes? We don't know of anyone with a lift who can help us out, and we're not mechanically inclined, so we'd end up having to pay whatever the cost...
Thanks very much in advance!
'93 Gr. Cherokee Laredo
'99 Cherokee Sport 3.5" RE Super Ride, 31" BFG A/Ts, Con-ferr rack and Hella 500s
'78 Porsche 911SC coupe
Wanted: front c4x4 tow hooks for XJ, rear class 3 tow hitch
NCjeepgirl83 is offline
post #2 of 12 Old 02-06-2013, 02:40 PM
fast_cobra_427
That's a ridiculous amount of money to replace pinion bearings. Do yourself a favor and go to a true repair shop. Not one of those corporate money hogs. It is common, but it's not really all that difficult of a job.
98 ZJ, 4.5" RC Series 2 X-Flex kit, 31x10.50x15 BfGoodrich KM2's, ARB Deluxe Winch Bumper, Factory Skids, JohnBuilt Rock slides, Aussie Locked up front, Mopar Trac-Loc out back
fast_cobra_427 is offline
post #3 of 12 Old 02-06-2013, 02:44 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
For 2 to 3K, you can buy a new super 35 with detroit locker and have it installed. That Firestone guy is ripping you off. Those costs are his standard $ per hour and then a good markup on your parts.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 12 Old 02-06-2013, 03:02 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Here's a link to quadratec as a reference only. You may find better prices if you look around.
http://www.quadratec.com/category/Je...n/54/index.htm
http://www.quadratec.com/products/16120_110X_PG.htm
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #5 of 12 Old 02-06-2013, 03:05 PM
Rich93ZJ
Any reputable shop should charge around 300-800 depending on if you actually need to replace the pinion and ring gears. If its just the bearing, I wouldn't pay more than $300. Ironically, I just finished tearing the axle out of mine to do a rebuild.
Rich93ZJ is offline
post #6 of 12 Old 02-06-2013, 03:48 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Rich is correct. Plus, if you are going to open the diff and work on the pinion, you might want to add a traction aid like a limited slip or locker. The diff is already open for business.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 12 Old 02-06-2013, 03:51 PM
xmonger
xmonger's Avatar
2003 WJ
Firstly, the last place I would go for differential work would be Firestone.
Secondly, $2-3k is outright thievery.
Post for a shop recommendation in your local forum on this site. A recommended 4x4 shop will do it right and save you a ton of money and hassle.
2003 WJ Overland 4.7 H.O.
xmonger is offline
post #8 of 12 Old 02-06-2013, 04:06 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Here's an idea? Angie's list?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #9 of 12 Old 02-10-2013, 07:33 AM
znm1994
2-3k is wayyyyyyy too much.. you can do it yourself for 1/4 the amount. Its not that hard either. I'm getting ready to rebuild mine
znm1994 is offline
post #10 of 12 Old 02-10-2013, 08:10 AM
riot1987
try to find an honest mechanic. The entire vehicle is worth 3000$. That mechanic is a chump
Build thread^^
riot1987 is offline
post #11 of 12 Old 02-10-2013, 11:10 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
That price is beyond insane.
Just doing the differential bearings should be a 500$ job with parts.
Don't just do the pinion bearings, carrier bearings should be done as well. Then it'll be good for another 200k.
Replacing just the bearings is under a 3hr job.
ratmonkey is offline
post #12 of 12 Old 02-10-2013, 02:26 PM
ajmorell
ajmorell's Avatar
X2. Might as well just do a full overhaul, bearings + races and seals at a minimum. I think I paid about $500 to have it done on my zj way back when.
ajmorell is offline
