93 ZJ fuel pump wiring problems - JeepForum.com
post #1 of 3 Old 04-06-2008, 10:08 PM Thread Starter
xjawgi
I need some help because im stumped with this problem..any suggestions would be appreciated.
Its a 93 zj 4.0 w/ about 159k. The other day i was getting off the highway and the jeep just died out of no where. It would crank but not start up. I popped the hood, hit the shrader valve and nothing, even while cranking the engine. Listed to the tank to see if i heard any humming and nothing. Tried hitting the tank with a hammer to activate the fuel pump - and nothing. So i had to bite the bullet and have it towed home.
Got it home, took a test light to the fuel pump connected at the back of the jeep and i am only getting a DIM light which happens to be for the fuel gauge. I checked the fuel pump relay and the 2 fuses, and those are good. I even swapped them out with ones i know work (i have an identical zj same year and engine that runs.) So i dropped the tank, pulled the pump and hooked the pump up to the other jeep, and the pump is good.
I pulled the distribution center away from the housing to check the wiring to see if any wiring is burnt, and its all nice and clean. I checked all the grounds and those are all tight and clean. I also swapped the auto shutdown relay and swapped it out with another and still nothing.
I put a test light to the 20A fuse labed ENG. CONTRL and its not lighting up like the other fuses are - does anyone know if that could be the problem? I even swapped the fuse with a new one and still no light.
Ive had over 10 jeeps and none have been this aggravating - any help would be appreciated!
xjawgi is offline
post #2 of 3 Old 04-06-2008, 11:57 PM
-Joe-
-Joe-'s Avatar
check for engine codes? some sensors can cause a no start..
The pump will only run for 1-2 seconds when the key is turned until the engine is started then it runs constantly.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 3 Old 04-07-2008, 04:26 PM Thread Starter
xjawgi
Alright ill do that. Thanks
xjawgi is offline
fuel pump wiring? brian86 ZJ Grand Cherokee Forum 6 03-28-2012 03:39 PM
WJ Fuel Pump Problems? BlackSS ZJ Grand Cherokee Forum 9 10-14-2009 05:28 PM
96 4.0 Fuel pump wiring diagram? pjbrady ZJ Grand Cherokee Forum 0 04-30-2009 01:25 AM
Fuel Pump Wiring - NEED HELP BliZZard911 ZJ Grand Cherokee Forum 1 07-20-2008 02:47 PM
Wiring Request For Fuel Pump BliZZard911 ZJ Grand Cherokee Forum 10 01-18-2008 08:04 PM
