93 ZJ 4.0L/AW4/249 "Slipping" at highway speed - JeepForum.com
post #1 of 12 Old 05-20-2011, 12:42 PM Thread Starter
93zjer
While driving over 45, and especially when not under acceleration or load my jeep will jump about 250-500 rpm (rpms go up) and I can feel a loss of power.
It only does this for a second ,literally, or maybe two, then rpms drop down to normal and its fine. It is intermittent. During a 1700 mile road trip it happened around a dozen times. Has not thrown any codes and runs very well other wise.
93zjer is offline
post #2 of 12 Old 05-20-2011, 01:12 PM
General_Jeep
1994 ZJ
how many miles are on this Jeep?
1994 Jeep Grand Cherokee 5.2L V8- NV3500 - Blown D35 8.8 replacement some day.
2010 Jeep Patriot 5 speed manual-- DD, 27-31MPG :D
1996 Dodge Ram 1500 - Work Truck/Plow 5.2L NV3500
2005 Nissan Titan - Hauler
"The Jeep is Americas only real sports car!" - Enzo Ferrari
General_Jeep is offline
post #3 of 12 Old 05-20-2011, 03:19 PM
savannahzj
mine does the same thing, usually with the cruise control on, above 55, it will jump about 200 rpms and then jump right back. mine is more like an rpm surge, so i was thinking tps.
savannahzj is offline
post #4 of 12 Old 05-20-2011, 05:41 PM
freakinheep89
sounds like the converter is unlocking/locking back in suddenly.
When you are even on the throttle and the TC lockup clutch is engaged, its a 1:1 drive. if the converter unlocks unprovoked(without you stomping the gas) the converter will slip a bit and the RPM will surge. I would start looking for anything that could be causing the converter to unlock randomly, like the TPS.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #5 of 12 Old 05-21-2011, 02:19 PM Thread Starter
93zjer
the jeep has about 220,000 miles but i took the engine out of a 95 ZJ that only had 60,000.
It ran with no problems for about a year then this started happening.
I thought the torque converter was unlocking but I noticed when the problem happens the RPMs only jump about 250-500rpm and when I use the gear selector the put it in third the jump is significantly more like 500-600.
Fourth gear is just the lock-up torque converter right? So I figured the difference in RPMs should be about the same if that is the problem I'm seeing is the torque converter unlocking for a second.
Is this line of thinking flawed?
93zjer is offline
post #6 of 12 Old 05-21-2011, 04:02 PM
Candymancan
Well 3rd is under overdrive, thats why the jump in rpm is higher, your turning overdrive off.
If you want to know for sure if its overdrive or the torque converter, simply drive the vehicle until the torque converter locks, then while your on the gas push the brake pedal slightly with your other foot and the torque converter should unlock. Take note of the rpm change and compare notes
Candymancan is offline
post #7 of 12 Old 05-21-2011, 07:58 PM
freakinheep89
Fourth gear is overdrive, then theres TC lockup. TC lockup is not overdrive.
Dropping the selector down a gear takes it out of overdrive, as candyman stated, causing the RPM surge.
the drop in RPM during lockup is about 250-300rpm on my 5.2.
TJ-
post #8 of 12 Old 05-21-2011, 09:14 PM Thread Starter
93zjer
OK, I thought that might be wrong, thnaks
So the fourth gear is referred to as overdrive meaning a 1:1 or greater ratio.
The torque converter "locks up" to sort of bypass the normal fluid coupling way it normal transmits power allowing for greater fuel efficiency?
I think I'm going to lean my IAC and replace the TPS.
I have the test procedure for the TSP but given the intermittent nature of my problem i doubt it would test bad.
93zjer is offline
post #9 of 12 Old 05-21-2011, 09:22 PM
freakinheep89
Now you got it
All TC lockup does is take the slip out of the converter and go from a fluid coupling to a mechanical lock.
As for the IAC, all that would do is create idle problems, typically they dont have any effect on driving unless they are stuck wide open.
One way to test the TPS(and the only real way, IMO) is with an analog volt meter to test the sweeping motion of the sensor. it should have a nice smooth sweep in voltage from idle to WOT, that cant be measured accurately without a needle to watch it sweep. if its jumps erratically its bad.
TJ-
post #10 of 12 Old 05-21-2011, 10:18 PM Thread Starter
93zjer
Thank you!
I completely understand.
I'll post my result here after I test.
93zjer is offline
post #11 of 12 Old 08-09-2011, 10:08 PM Thread Starter
93zjer
It was my TPS. Replaced it and never had the issue again.
93zjer is offline
post #12 of 12 Old 10-12-2013, 10:09 AM
cootertwo
1997 XJ Cherokee
On my 97 GCL my bad brake light switch was causing my TC lockup to go in and out.
cootertwo is offline
highway "sway", need HELP!! grandneuman ZJ Grand Cherokee Forum 14 03-22-2010 07:08 AM
WJ Front axle/brakes "Binding" at slow speed jasn1981 ZJ Grand Cherokee Forum 0 06-29-2009 09:54 PM
Idle speed control "problem" arieson35 ZJ Grand Cherokee Forum 10 11-06-2008 07:10 PM
Lower the Cruise "Set" Speed? adgjqetuo ZJ Grand Cherokee Forum 3 03-05-2007 01:04 PM
Aggrivating "skip" at highway speeds KC8RXQ ZJ Grand Cherokee Forum 8 08-18-2006 08:06 PM
