93 VIC in a 94 oil level light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 93 VIC in a 94 oil level light
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-04-2015, 07:18 AM   #1
jeepthing360
Good morning everyone. I had to replace the Vic unit in my 94. I grabbed a 93 unit and now I have the annoying check oil level light. Does anyone know which wire it is to turn it off. I thought it was 26 and tried a few different resistors and nothing seemed to help. I just want the light gone. Any help is appreciated.
jeepthing360 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2015, 09:32 AM   #2
AVR2
It's definitely pin 26:
My oil level sensor connector is broken, so when I specifically put the VIC into diagnostic mode it tells me that there's a problem with the sensor, but I don't get any warnings about it otherwise.
I don't know if it helps (probably not) but the FSM says that the oil level sensor uses a 0.75 milliamp circuit.
Here's the only other diagram from the FSM that might help you...
AVR2 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2015, 08:20 PM   #3
jeepthing360
Thanks for the info. I'll have to check that out tomorrow and see what I can figure out.
Unread 03-04-2015, 08:25 PM   #4
xcaliber81
1994 ZJ
How does the vic show the door open? I tried putting a 93 vic in my 94 and my 94 didn't like it and for the life of me I could not figure out how to show the door open
xcaliber81 is offline   Reply With Quote Quick reply to this message
Unread 03-05-2015, 12:31 AM   #5
AVR2
IIRC, the switches in the door frames ground when the door opens.
Unread 03-05-2015, 07:07 AM   #6
Cbob4
This is correct. depressing the switch (closing the door) completes the ground circuit. Unfortunately for mine, my issue is internal to the VIC as it always thinks my driver's door is ajar. Even tried grounding the pin in the connector to no avail. But I can live with it, as I like the service interval feature...
Cbob4 is offline   Reply With Quote Quick reply to this message
Unread 03-05-2015, 07:39 AM   #7
vlackattack
The solder joints on the circuit board go bad, if you open up your VIC and resolder them, it'll probably make the driver's door ajar message go away.
vlackattack is offline   Reply With Quote Quick reply to this message
Unread 03-05-2015, 08:51 AM   #8
xcaliber81
1994 ZJ
But I hooked up a vic and it never worked.
