93 vic. - JeepForum.com
post #1 of 15 Old 11-15-2013, 02:07 PM Thread Starter
xcaliber81
93 vic.
Is it the same as the 94-95? just wondering cause i have a 93 vic and i tried to put it in yes with the coolant and the lom but it was going crazy so i unplugged it. was telling me coolant sensor bad rear lamp failure and everything else but it worked perfect in the 93? just asking cause the wiring is different in the 93.
xcaliber81 is offline
post #2 of 15 Old 11-15-2013, 02:38 PM
RWC
The bad coolant sensor message can be repaired by soldering on the back of the VIC. Use the search function.
As for bad rear lights, there are lots of bulbs on the back of a ZJ. In the two ZJs that we've had, every time it told me I had a bad light and I thought it was lying, I actually ended up finding a bad rear light.
RWC is offline
post #3 of 15 Old 11-15-2013, 02:42 PM Thread Starter
xcaliber81
No bad lights and the coolant sensor worked with no warnings at all in the 93 its only telling me lies since ive put a 93 vic in a in my 94. Again it worked perfect in the 93 with NO messages at all.
My question is does the 93 vic have a different wiring setup than the 94-95 vics? Or will I need the vic from a 94 keep in mind I had a laredo and put limited stuff in it.
post #4 of 15 Old 11-15-2013, 02:43 PM
riot1987
Coolant message is a bad solder joint in the vic. A "new" one will most likely do the same.. Remove old VIC then,smash it with a hammer and call it a day.
Build thread^^
riot1987 is offline
post #5 of 15 Old 11-15-2013, 02:50 PM Thread Starter
xcaliber81
Sigh.... never said coolant sensor bad in the 93 I drove it to its final resting place and got to play with it. It worked perfect as it should have.
post #6 of 15 Old 11-15-2013, 02:52 PM Thread Starter
xcaliber81
The wiring setup is different in the 93 zj compared to the 94 zj is the reason im asking.
post #7 of 15 Old 11-15-2013, 04:23 PM
tucsonzj
wiring is the same from 93 to 95. They really are annoying, i just said f*** it and put in a 2wd cubby. Perfect place for my sunglasses.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #8 of 15 Old 11-15-2013, 04:30 PM Thread Starter
xcaliber81
actually I was just curious at this point im happy with my working gdm and since I have the overhead console I can store sunglasses there. I saw a cool link a while back about a vic alarm clock I might just do that instead lol.
post #9 of 15 Old 03-04-2015, 08:59 PM Thread Starter
xcaliber81
Im bumping this cause im still curious, my 93 vic doesnt like the 94 for some reason. When I parked the 93 I had no error messages no rear lamp failure or coolant sensor bad is there a difference in wiring somewhere?
post #10 of 15 Old 03-04-2015, 09:37 PM
zjosh93
Hmm... just looking around the forum it looks like a couple people have had issues putting 93 VICs into 94s or 95s. It's all one Mopar part number though, 56007088, so it shouldn't matter.
zjosh93 is online now
post #11 of 15 Old 03-04-2015, 09:39 PM Thread Starter
xcaliber81
That's what I don't get everyone is telling me there the same as well but 93 has the oil sensor and 94-95 did not so there a difference there.
post #12 of 15 Old 03-04-2015, 10:10 PM Thread Starter
xcaliber81
they have the same pinouts too, is there some kind of first time setup? Or does it normally just work on the first go.
post #13 of 15 Old 03-05-2015, 12:30 AM
AVR2
The 93-95 VIC is definitely the same part for all years. But how they got around the 94-95 ZJs not having the oil level sensor, I don't know.
AVR2 is offline
post #14 of 15 Old 03-05-2015, 08:52 AM Thread Starter
xcaliber81
Its still pin 26.
post #15 of 15 Old 04-06-2015, 08:39 AM
variable
variable's Avatar
FWIW, I just replaced the VIC in my 93 with one from - I think a 94 or 95 - and I finally tracked down all the bulbs it was complaining about in the 'rear lamp failure' message - turns out one of the two 'third' break light bulbs was bad - and it went away... and then came back a few days later. I've replaced ALL the rear bulbs... I got nuthin. Given common fixes on these things seem to be 'resoldering' something or other, wouldn't surprise me to find that to be the fix for this one as well... Its not like they're making new ones for our ye olde ZJ's... Been thinking about replacing it with something arduino based. Have to track down a lot of wires though... :-P
93 ZJ V8 5.2 - K&N FIPK, leaky exhaust
variable is offline
