93 with rebuilt 4.0 having overheating issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 93 with rebuilt 4.0 having overheating issues
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 11-03-2009, 11:48 AM   #1
richhunter
1993 XJ Cherokee
Has a rebuilt 4.0 with a new radiator,new water pump,new thermostat,new fan clutch,new hoses and have blown out bugs and dirt out of Ac condenser and tranny cooler! It is not losing coolant or needing any added to it it just overheats when climbing a long grade or with the AC on and moving slow in rush hour traffic! Any ideas or suggestions on what I may be overlooking? Thanks
richhunter is offline   Reply With Quote
Unread 11-03-2009, 11:58 AM   #2
JesseOR
Was the cooling system properly bled(burped)?
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline   Reply With Quote
Unread 11-03-2009, 12:07 PM   #3
richhunter
1993 XJ Cherokee
Yes it was.Does not overheat when it is cool outside and the heater works just fine.
Unread 11-03-2009, 12:08 PM   #4
richhunter
1993 XJ Cherokee
And yes I do have a fan shroud as well as a new belt
Unread 11-03-2009, 12:14 PM   #5
richhunter
1993 XJ Cherokee
And I checked to see if there was oil in cooling system or coolant in the oil and there is none so I dont think the head gasket is bad. Not to mention it runs great!
Unread 11-03-2009, 12:44 PM   #6
JesseOR
Try running it with no thermostat.
-Jesse-
GO DUCKS!
Unread 11-03-2009, 12:49 PM   #7
richhunter
1993 XJ Cherokee
Did that also had to put it back in due to a cold spell and barely any heat inside.
