'93 Rear Brake Conversion - JeepForum.com
post #1 of 11 Old 08-18-2013, 06:32 PM Thread Starter
Raimundo
Hi there. I want to go Rear DISC Brakes on my '93 ZJ. Is there a specific model year that I should get the parts from or can I just get them from any one from '95 to '98?. Thanks
Raimundo is offline
post #2 of 11 Old 08-18-2013, 06:37 PM
fljeepney
I think Iron Rock Offroad sells the conversion kits,but if that's not the way you want to go,then I assume you would have to pull everything from a ZJ that came with rear disc.
Good Luck
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
1985 Corolla AE86 coupe
fljeepney is offline
post #3 of 11 Old 08-18-2013, 06:55 PM Thread Starter
Raimundo
Hey fljeepney! Nice ride. Mine looks similar( no fire), I'll post pictures soon. So, I now I can save a lot of $$ if I pull it myself from a yard but,,Can I use ANY from '95 to '98? Thanks
Raimundo is offline
post #4 of 11 Old 08-18-2013, 07:25 PM
fljeepney
Actually,that's an old ad when the 5.9s came out,but I have a white one I just bought not long ago.I cant really say if it would work,but I'm very sure someone else will chime in on it.
For mine,I'm going to replace all 4 rotors with slotted ones for more stopping power,plus minimal brake dust.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
post #5 of 11 Old 08-18-2013, 07:30 PM
dnuccio
ZJ disc brake hardware was the same across all years AFAIK
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 11 Old 08-18-2013, 08:38 PM Thread Starter
Raimundo
Thank you "dnuccio" for the info: Hey jeepney; I HIGHLY recommend BRAKEPERFORMANCE.COM.I purchased front "slotted/dimpled drilled"(partially drilled) from them about 7 months ago. Those are amazing. My '93 stops so evenly,quick and with NOT a bit of vibration etc, also, after 7 months, they don't have not even a scratch on them vs the groves you'd get in flat ones, the grove in the rotor keeps the pad super clean, avoiding particles to accumulate in between, what causes rotor deep groves and warping. they also work a lot cooler, I use ceramic pads and barely dust. very good product and serious customer service. Well, I was just looking online and they all want over $500.00 for the hall kit.So, I have to do my numbers because I'm not using the flat rotors. I think I'll just get the calipers and bracket/plate from the yard, then I can get new calipers for $20.00 each (returning the old one) and the rest I'll get it new, like parking shoes and cables. I'll do the numbers and post back ok? good luck and thanks again.
Raimundo is offline
post #7 of 11 Old 08-18-2013, 08:43 PM
Y0ungGunZJ
No 93s came with disc 94-98 have disc as standard.
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #8 of 11 Old 08-18-2013, 09:47 PM
dnuccio
94 limiteds have discs, 94 laredos still had drums. 95 everything got discs
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 11 Old 08-19-2013, 06:53 PM
fljeepney
Not a problem,glad I could help somewhat.I really appreciate giving me that site coz my 5.9 could use a stronger brake setup.Hope your swap goes well,and take pics of the swap.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
post #10 of 11 Old 08-19-2013, 10:17 PM
xcaliber81
you mean all model gc from 95 and up had disks in the rear?
xcaliber81 is offline
post #11 of 11 Old 08-19-2013, 10:36 PM
coltman151
Yep. My 95 laredos got discs. 94 be the last year of da drums.
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
