'93 idle fluctuation and missing - JeepForum.com
post #1 of 12 Old 12-06-2003, 10:37 AM Thread Starter
Choff
Hi
My '93 4.0L inline 6 recently had been having issues with idling very high-- around 1500-2k. It would obviously bang into reverse, etc. Now, I found a fairly siginificant vacuum leak, on the hose that connects to the plastic "pcv valve lookalike" on the end of the valve cover near the firewall. Having fixed this, it appears that the idling is more normal (though still a little high).
However, now it misses when idling (especially when not in gear), hesitates when taking off, and smells strange.
I thought that perhaps the computer just needed to be reset, so I unhooked the battery for a few hours. No dice. Then, I ran about a half a can of Seafoam in through a vacuum line (as well as putting some in the fuel tank). Also didn't help. I then took some starter fluid and started spraying it on vacuum lines to look for another leak, also nothing. The plugs, wires, cap, and rotor are all new within the past 6 months. The air cleaner is also fine. All the wires are tightly seated, and I pulled the plugs (Bosch Platinum +2) and they all look fine.
I'm not really sure where else to go here.
ANy ideas would be appreciated.
p.s. the fuel pump is also new within about 20k or so
Thanks for reading
Chris
edit: I also pulled the boot off of the throttle body and looked in there. It looks a little dirty. I wonder if this could contribute? I do find it hard to believe that this could be the cause though... but again, I really don't have any other ideas...
Choff is offline
post #2 of 12 Old 12-09-2003, 12:21 PM
4XHI
how is your temp gauge reading??
if its above where it typically runs when idling it may simply be the oxygen sensor. Normally this will drop the rpms though and not raise them.. I'm willing to bet at any rate its a sensor..
rob
4XHI is offline
post #3 of 12 Old 12-09-2003, 09:10 PM
DrewT
Originally Posted by 4XHI
... I'm willing to bet at any rate its a sensor...
Probally. Do you have a CEL? If so, pull the codes, and post them. Also, check your mileage, it is probally the O2 Sensor...
DrewT is offline
post #4 of 12 Old 12-14-2003, 08:28 AM Thread Starter
Choff
HI
thanks for the responses.
I'll probably have to take it in to have it hooked up to a computer to see what's up. I'm not sure if the temp is reading higher than it used to... the jeep came with my new wife, so I'm not sure how it used to be.
I was actually thinking of the O2 sensor. The thing has 116000 on it.
Any idea how much the O2 sensor runs, and is it something I can get to and easily replace myself?
Thanks!
Chris
Choff is offline
post #5 of 12 Old 12-23-2003, 01:22 PM
automan25
Very easy to replace. Took about 15 minutes on my '93 V8. The cost looks to be about $62.49 at NAPA online.
http://www.napaonline.com/cgi-bin/nc...grpid=28591068
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #6 of 12 Old 12-23-2003, 04:09 PM
RockPaws
RockPaws's Avatar
It sounds more like the Air idle control valve. They can get sticky and cause this problem. You may be able to remove th evalve and clean with some carb cleaner. If you still have the problem, change the throttle position sensor.
I have seen this problem on a number of customers vehicles, its nomally one or the other. You may take it to Auto Zone and have them test it with their computer.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #7 of 12 Old 12-28-2003, 11:04 AM Thread Starter
Choff
Is that the small round valve, near the front of the engine, on the FI rail (not sure of the proper term for that) with a large vacuum line attached to it?
I also noticed that the throttle body has a lot of black deposits around the butterfly.
Thanks
Chris
Choff is offline
post #8 of 12 Old 12-30-2003, 07:33 PM
RockPaws
RockPaws's Avatar
The round valve on the fwd end of the fuel rail, is the Fuel Pressure regulator. It is controlled by vacume pressure.
I clean my throttle valve valves with fuel injection spray cleaner. With the engine off, I spray around the valve area. Then open it, and finish off the bottom side and bore area.
RockPaws is offline
post #9 of 12 Old 12-30-2003, 07:59 PM Thread Starter
Choff
I cleaned everything I could clean and plugged up the vacuum leak again. It still misses and hesitates, idle fluctuates, and smells funny... but not as badly as before. I think I will have to have it checked out. The check engine light is not on, but maybe if they poll the computer they can find something (or see something I did not)
It drive me crazy when my vehicles aren't running right!
Thanks
Chris
Choff is offline
post #10 of 12 Old 07-22-2004, 06:45 AM
drjake77
Missing
Choff what did you ever find out what the problem was my 93 is doing the same thing
drjake77 is offline
post #11 of 12 Old 07-22-2004, 03:15 PM Thread Starter
Choff
I replaced the O2 sensor and cleaned the IAC valve. It was all better after that.
HTH
Chris
Choff is offline
post #12 of 12 Old 09-09-2004, 09:57 PM
boxoffire
Rockpaws, you hit the nail on the head in my case. I have a 93 that was idleing high at startup sometimes and wouldn't come back down. Then it would stall out at stop lights sometimes cause idle was too low. Carried to my mechanic and he replaced that valve you mentioned (Air idler control valve) and I spent freakin $260 to have it all fixed. Wonder if I could have just had it cleaned like you suggested, or was he probably being straight up that it needed replacing? It did fix the problem, so far, though he may need to readjust it somewhat cause it seems to idle a bit low and especially when A/c is running. Thanks.
boxoffire is offline
High idle, rpm fluctuation...HELP! NJWJ ZJ Grand Cherokee Forum 7 08-03-2011 02:22 PM
93 4.0 bad idle like its missing. fxstse ZJ Grand Cherokee Forum 4 12-01-2009 07:44 PM
5.9L Missing at idle bcollier1823 ZJ Grand Cherokee Forum 10 05-10-2009 05:45 PM
Bad idle, missing, and some codes RyanZJ ZJ Grand Cherokee Forum 26 04-23-2007 04:39 PM
Idle fluctuation and defroster 2Xtreme WJ Grand Cherokee Forum 18 12-12-2003 01:55 PM
