93 Grand w/ dana 35c Question - JeepForum.com
post #1 of 2 Old 03-10-2004, 04:00 PM Thread Starter
Rjwrangler
My 93 ZJ has a problem. Has anyone here replaced the rear wheel bearing and seal? Mine have killed the rear brakes and flooded the drums with fluid! I need to know what tools you used to pull out the bearings? Any help will be appreciated. Thanks
My DC build sheet calls the rear axle a Dana M35/194MM
98 TJ 4.0L Auto
Rubi suspension, 2"BB, 1"BL
33x12.5x15 TrXus MT's
15x8 Rock Crawlers(Black)
Live to Wheel, Wheel to live!
Rjwrangler is offline
post #2 of 2 Old 03-11-2004, 07:43 AM
Swamp Boy
Swamp Boy's Avatar
I just used a long piece of 1" pipe. Drove the passenger side bearing out from the drivers side.. I am sure that is not the right way but it worked for me.. The seal is easy you just remove your diff and pull it out.. They are right near the diff in the axle tubes..
Either way.. you are going to have to take the axle apart..
Good luck
Just another soccer moms Grocery getter....
Swamp Boy is offline
Dana 44 97 Grand Cherokee? EdinMN ZJ Grand Cherokee Forum 2 12-23-2009 09:51 AM
will dana 30 from 95 wrangler fit a 94 grand cherokee justin815 ZJ Grand Cherokee Forum 3 05-13-2009 01:58 PM
96 Grand Dana 44 Aluminum Rebuild pinion setup questions: Shop Teacher needs teaching twisted_ed ZJ Grand Cherokee Forum 1 03-25-2009 10:07 PM
Dana 30 on a 99' Grand Cherokee WJ Irishterd ZJ Grand Cherokee Forum 7 02-26-2009 08:24 PM
TJ Dana 44's in a Grand Cherokee rustynail ZJ Grand Cherokee Forum 8 02-18-2009 05:00 PM
