93 Grand Cherokee start problem - JeepForum.com
post #1 of 16 Old 11-17-2005, 07:28 PM Thread Starter
BUMMER
I have a 93 G. Cherokee with a 4.0 with starting problems. I have to turn the ignition switch to the on position for about 90 seconds before I hear a relay energize in the power distribution box and the jeep will start. It will keep starting as long as I don't let it sit to long. But when I go to start it the next day the problem starts all over again. Once it starts it runs fine. If the fuel pump is losing pressure it should'nt take 90 seconds to build up pressure. Has anyone experienced this problem before. Thanks
BUMMER is offline
post #2 of 16 Old 11-17-2005, 07:35 PM
Jeep-Tech1
Could be the ASD relay. But you will probably be better off to go ahead and get a PCM and it should correct your problem.
Jeep-Tech1 is offline
post #3 of 16 Old 11-17-2005, 07:47 PM
guango88
Air Trans
guango88's Avatar
have you change your fuel filter lately?
ONE ABOVE ALL
guango88 is offline
post #4 of 16 Old 11-17-2005, 07:52 PM
Jeep-Tech1
and bummer i have seen this very same problem before to the T. And I diagnosed it to be the PCM. And guess what.............................................. ........ It was. Put a PCM on there and like magic it fixed it. Man you just dont know what a good technician and a fluke meter can figure out. Thats why I get payed as much as I do.Cause I eat, sleep, and breath and s__t jeeps from 8-6 mon-fri all year long....
post #5 of 16 Old 11-17-2005, 07:56 PM
guango88
Air Trans
guango88's Avatar
well, another problem solved
ONE ABOVE ALL
guango88 is offline
post #6 of 16 Old 11-18-2005, 10:58 AM
sastanley
Hi guys...new member...I seem to be having a similar problem, but I am pretty new to Jeeps and need some acronym help, like what a PCM is.
My wife cranks our GC for 15-20 secs now that it is cold out and gets it to cough and then cranks it again and it will start...runs fine, but hard to start in the cold.
Mechanic buddy mentioned check valve's etc..that may be not holding fuel in the lines or fuel enrichment features may be mafunctioning..
Willing to take all suggestions...just need some guidance from the experts.
Thanks!
edit - Hi - Reading FAQ's now...ignore my newbie post
sastanley is offline
post #7 of 16 Old 11-18-2005, 12:27 PM
Jeep-Tech1
What year is your grand?
post #8 of 16 Old 11-18-2005, 01:50 PM
poconosms1
what is the PCM
I;m having the same problem, so what is the PCM?
1993 Jeep Grand Cherokee.
base model, but added leather seats.
179,000
East Stroudsburg, PA
poconosms1 is offline
post #9 of 16 Old 11-18-2005, 01:53 PM
greasefingers
greasefingers's Avatar
1994 ZJ
PCM=ECU=computer
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #10 of 16 Old 11-21-2005, 09:50 PM
geeves66
loss of standby fuel pressure
I am in the process of finding out why Grand 2002 4.0 does the same thing. So far this is what my mechanic and I found. Fuel pressure at fuel rail 52# during idle. When engine shuts off, fuel pressure supposed to hold pressure for around 10 min (i think) My pressure drops to 0 in approx 10 sec. Bubbles in the fuel rail when purged. (due to heat boiling the fuel at low pressure in line) Could have injector leaking or fuel tank check valve leaking. I am hoping for the check valve problem. I am changing my filter/regulator tomorrow and adding an inline fuel check valve to try first. If that don't work, I will just change all injectors with new ones. Bosch set around $180 i think. GM service bulletins have a known problem with the check valve in the tank. And dealer does not sell just the valve. Write up says you need to change the tank. This is a recall on some models. Will try and go that route if this be the problem. And that is my two cents.
Geeves
geeves66 is offline
post #11 of 16 Old 02-23-2006, 02:22 PM
sastanley
Geez...sorry I am a slacker..
I have a '93 ZJ with the I6. I've since done some more searching and FAQ reading and pretty sure it is the PCM, as mentioned here. It's been three months and it isn't getting any better. Does it eventually just not work anymore and you get stranded?
I have a little extra cash now so I am going to dig under the hood today and see which ECM I have so I can order one from these rock auto dudes.
post #12 of 16 Old 08-03-2015, 03:51 PM
taborinni
So @sastanley - you never followed up on if you were able to fix your 93 ZJ 4.0L I6. It sounds like a problem I've been having with my 93 GC. I am at the point where the PCM almost seems to be the only thing left and would appreciate it if you could let me know what you ultimately had to do to your 93? Here's a description of what I'm experiencing and what I have done:
I have replaced the spark plugs, plug wires, distributor cap and rotor, fuel pump, fuel filter, distributor (new, including camshaft position sensor), crankshaft position sensor and nothing makes any difference. It is practically impossible to start. So, I am going back to the basic troubleshooting, even though I did these things before when I began having problems with it. One guy told me to check the engine temperature sensor and wiring as it could cause the stalling, super long crank times, spitting and backfiring, dieseling, popping and spitting back and quickly losing all engine power at highway speeds when pressing the accelerator pedal aggressively as well as in town speeds or stopped. It is much more difficult to keep running at in speeds or stopped than at highway speeds.
I really appreciate your response!
taborinni is offline
post #13 of 16 Old 08-03-2015, 07:24 PM
Rich93ZJ
Sorry im a little late to the party but here is the fix to your PCM issue. OBD1 only. Did mine about a year ago and still flawless
http://www.jeepforum.com/forum/f13/f...riteup-501951/
93 ZJ 5.2V8 3.5 iro 31x10.5
08 Silverado 6in lift 35's
Rich93ZJ is offline
post #14 of 16 Old 08-04-2015, 09:25 PM
taborinni
93 ZJ Starting Issues
Was your ZJ having the same issues my 93 ZJ is? Thanks a bunch!
post #15 of 16 Old 08-06-2015, 04:38 AM
Rich93ZJ
Mine would not start until the check engine light went off. I had to keep the ignition on for about 10 minutes before it would fire. After doing the surgery on the PCM, it fires off as soon as i hit the key. My capacitors did not physically look bad but it was defiantly the issue. If you know how to solder and have basic mechanical skills, you can get this done in a about an hour. I think it cost me a total of less than $5.00. Here is the link if you want to buy them.
http://www.ebay.com/itm/5pcs-220uF-3...item418b3863fa
Rich93ZJ is offline
Grand Cherokee Diesel Cold Start problem rmpt ZJ Grand Cherokee Forum 11 12-24-2010 07:48 PM
96 Grand Cherokee Wierd Start Up Problem BOBO9530 ZJ Grand Cherokee Forum 1 09-18-2008 09:23 AM
93 Grand Cherokee Hard / Rough Start Problem scoutdog ZJ Grand Cherokee Forum 3 05-07-2008 05:07 AM
94 Grand Cherokee Cold Start Problem FDSJr ZJ Grand Cherokee Forum 6 11-01-2005 09:05 PM
1997 Grand Cherokee No Start Alarm Problem? Andrewiski ZJ Grand Cherokee Forum 0 03-08-2004 10:12 PM
