93 grand cherokee problems starting - JeepForum.com
post #1 of 24 Old 03-27-2008, 08:08 PM Thread Starter
85cj7thing
just got the cherokee.. knew there were some problems. got it home fine about 10 miles drive... parked it next day went out would not start.. fuse box under the hood is clicking. opened it up its the.. fuel pump fuse and auto shutdown fuse.. after a little while it stops.. all this when key is in the on postion.. i pushed the valve down on the fuel rail and nothing... i got spark just no fuel... so is it really the fuel pump or the fuse.??? and what is the auto shutdown fuse??is there away to hotwire the fuel pump... i have read the forums for about 2 days now and cant get a clear answer.. to this question but have answered alot of question i did have... this site is pretty kool
oh yea im not new to jeeps just the zjs i have 4 cj7 and one is in the rebuild stage
85cj7thing is offline
post #2 of 24 Old 03-28-2008, 07:27 AM
subliminal
1997 XJ Cherokee
Replace those 2 fuses if it still doesnt work check the relay if its not that you will be buying yourself a new fuel pump in the near future.
subliminal is offline
post #3 of 24 Old 03-28-2008, 02:25 PM Thread Starter
85cj7thing
relay were is it i cant find it....
post #4 of 24 Old 03-28-2008, 04:21 PM Thread Starter
85cj7thing
could it be the anittheft??? is there away to baypass that???
post #5 of 24 Old 03-28-2008, 04:36 PM
a70eliminator
I'm pretty sure the anti theft system cuts out the ignition, you have no fuel pressure at the schreader valve on the fuel rail. Get youself a can of eyther starting fluid or even just a splash of gasoline, take off the air intake hose at the throttle body and give it a squirt, immediatly try to start it, if it starts then suspect the fuel system, if no start then your looking at some electrical troubleshooting. I'm guessing when if you give that a try you'll get a momentary start-up.
a70eliminator is offline
post #6 of 24 Old 03-28-2008, 04:38 PM
Windowsrookie
If he's got no fuel pressure he's looking at fuel problems, not electrical.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #7 of 24 Old 03-28-2008, 04:41 PM
a70eliminator
post #8 of 24 Old 03-28-2008, 04:44 PM
Windowsrookie
Yes I did. Starting fluid isn't going to help at all. Starting fluid doesn't even need electricity to burn.
He also already stated he has spark.
1987 Wrangler 4.2L
post #9 of 24 Old 03-28-2008, 04:55 PM Thread Starter
85cj7thing
correct no spark no fuel... i kinda wanna narrow it down fuel pump is 250 around here in cincinnat..... coil tested out ok new fuses???? my light were blinking and i read you have to turn the jey on the drive door to stop it and that worked????????? idk im at a stand still here
post #10 of 24 Old 03-28-2008, 05:03 PM
a70eliminator
Ah, so you re-set the anti theft system, do you know what caused it to activate in the first place? There are ways to disable it.
post #11 of 24 Old 03-28-2008, 05:05 PM
LeroyJMC
1994 ZJ
Sounds like it's probably functioning properly to me. That's exactly how the anti-theft is supposed to work. You disarm it by using the key in the drivers door. Check the owners manual on the operation of it.
Check your battery and terminal connections. My battery was weak and my terminal connections were all corroded causing my anti-theft to shut down the ignition/fuel system several times before I figured out what was causing it.
2009 Red Rock JK Unlimited Rubi
2006 Scion xA
1999 WJ Limited Quadradrive V8
1997 Chevrolet Z71
1994 ZJ Laredo 4.0 - Sold
Thanks for the IR Remote Smokinbk.
LeroyJMC is offline
post #12 of 24 Old 03-28-2008, 05:26 PM
Windowsrookie
You have no spark now too? In your first post you said you have spark.
1987 Wrangler 4.2L
post #13 of 24 Old 03-28-2008, 05:37 PM Thread Starter
85cj7thing
i did but now i dont have spark
i have no onwers manual
post #14 of 24 Old 03-28-2008, 06:02 PM
a70eliminator
First make sure the anti-theft is working properly. Get into the drivers seat and lock all the doors using the door lock button on the driver door panel, you may or may not need to have the key on to do it. Watch for the flashing security light in the instrument cluster, it should flash 3 or 4 times to let you know the system is armed, now simply open your drivers door using the release handle, your lights will flash and your horn will sound at the same time, now take your key and turn the driver door lock to the left and your system should disable. As someone already stated bad connections on your battery can do weird things so make sure they are clean and tight.
post #15 of 24 Old 03-28-2008, 06:13 PM Thread Starter
85cj7thing
horn ddint go off just the lights...
i just went out and tried to start it turned the key in the on postion and it started clicking fast 3 clicks or so a second. so i let it click when it finished clicking.. the was fuel at the rail and it started right up.. and is runnning at this moment... so i have no idea... this site is great.. has helped me on my cj a couple times lol.. is the clicking a warning the pump is going???
1996 Grand Cherokee - Starting problems - Flooded? prefect4me ZJ Grand Cherokee Forum 9 08-06-2015 11:36 AM
94 Grand Cherokee starting problems usmcmarpat ZJ Grand Cherokee Forum 15 01-01-2010 08:34 AM
08 Grand Cherokee starting problems 08GCjeep WK Grand Cherokee & XK Commander Forum 13 12-29-2009 10:50 PM
2006 5.7L Grand Cherokee starting problems andersjr82 WK Grand Cherokee & XK Commander Forum 2 10-18-2009 08:27 PM
93 Grand Cherokee Lardeo has problems starting! Help! SRH_91 ZJ Grand Cherokee Forum 11 09-28-2008 12:02 PM
