93' grand cherokee laredo axle noise? help - JeepForum.com
post #1 of 2 Old 12-30-2010, 12:30 PM Thread Starter
blackbeard2009
I have 1993 grand Cherokee Laredo that has recently just had the front end replaced. The gears, ring and pinion, and axles were replaces all at the same time. ran fine for about month now there is a loud knocking noise (ill try to be as descriptive as possible). When i get on the gas everything is fine when i let off it starts to knock mostly on the drivers side it feels. when i brake it stops until i let off the brakes again. I jacked it up and it feels there is slake when i turn the tire by hand, feels like there is slop but i don't wanna tear it all apart without some advice.
What would you do first? problem checklist i guess. Any help is greatly appreciated!
blackbeard2009 is offline
post #2 of 2 Old 12-30-2010, 01:23 PM
JrMechanic
Check if the brake pads are properly shimmed. XJ's, ZJ's, and TJ's are notorious for wearing out the pad rails on the knuckle. If there's too much clearance, the pads can move up and down making a loud and annoying knocking sound.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
axle , gears , jeep , laredo , noise
99 Grand Cherokee Laredo Robsho67 ZJ Grand Cherokee Forum 11 12-17-2008 08:34 PM
4 WD 97 Grand Ch Laredo Auto Trans Noise jchevas WK Grand Cherokee & XK Commander Forum 2 10-01-2006 10:06 AM
2006 V6 Grand Cherokee Laredo Rear Differential Noise strdotmatt ZJ Grand Cherokee Forum 5 07-25-2006 01:26 PM
2001 Grand Cherokee Laredo rattling noise ArcticAlaskan ZJ Grand Cherokee Forum 2 06-11-2006 10:00 AM
Rear Axle Seal 95 Grand Cherokee Laredo eprovenzano ZJ Grand Cherokee Forum 0 01-24-2006 09:07 AM
