93 grand cherokee just died - JeepForum.com
post #1 of 4 Old 09-03-2006, 08:59 PM Thread Starter
my94cherokee
Ive got a 1993 grand cherokee with a 6cyl auto 249 transfer case. i just did the cap rotor and plugs. after driving the truck for a little while i went into a store and came out started the truck and it started then died. it started right back up. a little while later i shut the car off. it sat for maybe about an hour then it took 3 times to get it started. after that its been fine. i know the wires need to be changed but would these situations be caused by bad wires. also the truck idles at about 400 rpms what is normal.
my94cherokee is offline
post #2 of 4 Old 09-03-2006, 09:54 PM
micifus
Original GC'er
micifus's Avatar
something could be loose check all of your wires and be sure the cap is seated properly
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #3 of 4 Old 09-03-2006, 11:31 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Can you hear your fuel pump kick on when you first turn the ignition on? Sounds like your pump is on it's way out.
I'd check the pressure to the fuel rail and see where you are at.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #4 of 4 Old 09-04-2006, 09:15 PM Thread Starter
my94cherokee
hey thanks im gonna check the cap tomorrow mornign when i get up. the wires are all tight. thanks for the help
02 Grand Cherokee (4.7/auto/awd) just died...no juice at all blue89bird ZJ Grand Cherokee Forum 21 03-26-2017 05:28 PM
99 Grand Cherokee Died today... Help twmart ZJ Grand Cherokee Forum 9 03-26-2017 10:43 AM
2008 Grand Cherokee Died suddenly JohnDeerCJ WK Grand Cherokee & XK Commander Forum 6 07-08-2009 06:19 PM
1997 Grand Cherokee Fuel Pump Died!! dirthound ZJ Grand Cherokee Forum 11 03-01-2009 11:32 PM
grand cherokee died freeburg ZJ Grand Cherokee Forum 4 11-29-2005 08:28 PM
