93 Grand cherokee fuel pump - JeepForum.com
post #1 of 8 Old 12-10-2007, 05:34 PM Thread Starter
toms93grand
93 grand 4.0L, fuel pump does not cycle on during cold start. fuel pump replaced, relay is good. If key left in run position while checking under hood after a few minutes I can hear the fuel pump relay chatter and then close, pump comes on for a few seconds to charge fuel manifold and then I can start. The relay is known functional by swapping with starter relay(same pn#) removed case from relay to mechanically engage contacts, fuel pump runs however even if i charge up manifold this way, will not start.
toms93grand is offline
post #2 of 8 Old 12-10-2007, 10:51 PM
-Joe-
-Joe-'s Avatar
Some have noted this can be caused by bad capacitors in the pcm.
You could pull and check for swollen or leaking caps.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 8 Old 12-11-2007, 03:19 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Yep that’s a lazy PCM powering-up. Replace it or tear it apart and replace the three capacitors that Joe is speaking about.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 8 Old 12-11-2007, 08:35 PM
-Joe-
-Joe-'s Avatar
I just replaced like 12 of them on an old motherboard.
- Joe -
-Joe- is offline
post #5 of 8 Old 12-12-2007, 08:00 PM Thread Starter
toms93grand
Thanks a lot guys, I will take a look at the caps in PCM, or see if I can get one from a junkie. Is there any issue with swaping the PCM with a used one that I should know about?
thanks! Tom
post #6 of 8 Old 12-15-2007, 10:22 AM Thread Starter
toms93grand
Thats It!!!
You guys were right on the money! Pulled the PCM and 1 of the 3 large caps was swollen.
Now I know root cause of this issue
Thanks a lot
post #7 of 8 Old 12-15-2007, 10:33 AM
indept
Thanks a lot
I found rubbing make the swelling go down
How about some pics showing which capacitor
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #8 of 8 Old 12-30-2007, 05:49 PM Thread Starter
toms93grand
Left myself open for that one! Still laughing
Replaced the 220uF cap and the thing is now alive again...
Like how Jeep pots the motherboard so you can't work on it!
01 Grand Cherokee fuel pump replacement rkreger2 WJ Grand Cherokee Forum 18 03-16-2016 11:35 AM
5.9L Grand Cherokee Fuel Pump Issue bandanaboyz ZJ Grand Cherokee Forum 7 10-10-2009 03:54 PM
96 grand cherokee fuel pump woes turbojeep88 ZJ Grand Cherokee Forum 8 09-16-2009 09:44 AM
06 Grand Cherokee fuel pump problems?? Busther WK Grand Cherokee & XK Commander Forum 0 12-13-2006 09:39 AM
96 Grand Cherokee fuel pump change carrolles ZJ Grand Cherokee Forum 4 12-14-2002 11:40 PM
