93 gc rear axle swap question - JeepForum.com
post #1 of 8 Old 06-27-2013, 12:43 PM Thread Starter
justinspotanske
This maybe a dumb question but I thought I would ask . I have a 93 gc with the s6 and the d35 rearend with drums . I have read on here that 96 s and so on came with rotors . Is this a swap I would be able to do and what would be involved ( would it be the whole axle or just the shafts ) . I also tow a boat that weighs about 1000 lbs if that matters or should I just stick with the drums . The reason I ask if its the whole axle icause When I had my alignment don the told me that my rear was a hair bent which is causing excessive wear on one side . So my other question is should I go to the wrecking yard to get another axle or I have a local frame shop that computer aligns and can do rear axles . Im just afraid to go to the wrecking yard and the one that I pull Is slightly bent also . which do you recommend . The shop only charges 125 to 160 to align the rear axle
justinspotanske is offline
post #2 of 8 Old 06-27-2013, 12:44 PM
WhiteOut
WhiteOut's Avatar
How do they plan to compensate for a bent axle?
WhiteOut is offline
post #3 of 8 Old 06-27-2013, 12:53 PM Thread Starter
justinspotanske
from what he said is hook it up and bend it back . no heat . It is a frame shop not a back yard deal
post #4 of 8 Old 06-27-2013, 12:55 PM
WhiteOut
WhiteOut's Avatar
I would just swap in a new axle. There is no way they would only charge $160 to R&R an axle plus try and bend it back to shape.
WhiteOut is offline
post #5 of 8 Old 06-27-2013, 08:13 PM Thread Starter
justinspotanske
Btt
post #6 of 8 Old 06-27-2013, 09:39 PM
dnuccio
junkyard axle if yours is bent. for disc brakes, you can look at a 1994 limited model, or any ZJ after that. they changed all of them to discs in 95, limiteds got them in 94.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 8 Old 06-27-2013, 10:34 PM Thread Starter
justinspotanske
Would it be a straight swap with no issues with the exsisting abs system , computer etc ?
post #8 of 8 Old 06-29-2013, 11:39 AM Thread Starter
justinspotanske
Btt
