93 GC normal running temprature - JeepForum.com
post #1 of 6 Old 07-08-2002, 10:52 AM Thread Starter
Jackylman
Whats the normal running temp of the Grand Cherokee 4.0L. In this hot temprature mine is running in between 215 and 220 highway speed 80mph with the A/C on. I can turn the A/C off and it will drop to 210.
Jackylman is offline
post #2 of 6 Old 07-08-2002, 01:41 PM
Drafter75
That seems to be in the normal operating temp range for this engine.
Drafter75
Proud V8 ZJ/WJ owner of
1993-1998-1999-2002 model years.
Have you hugged your Jeep today?
Drafter75 is offline
post #3 of 6 Old 07-08-2002, 03:49 PM Thread Starter
Jackylman
Thanks for the info. It just seems a little high to me. Especially when in the winter or cooler weather I can't get it to break 210.
post #4 of 6 Old 07-09-2002, 10:03 PM
Intrepidjeep
Intrepidjeep's Avatar
Your radiator is probably not flowing as freely as it did in its younger days.
You can certainly try putting in a cooler thermostat.
-- Marcus
Cape Canaveral, Florida
2005 Jeep Grand Cherokee Laredo 4.7L
2005 Dodge Durango SLT 4.7L
Intrepidjeep is offline
post #5 of 6 Old 07-10-2002, 11:29 AM Thread Starter
Jackylman
Bran new radiator. Water pumps about a year old and the cooling system has been flushed. Went from a 1 core radiator to a 2 core. The one core would just keep on climbing till it pegged out. This 2 core seems to stop at 220. That just sounds high to me though. So I'm looking for information on normal running temps on this engine. Is 220 within its limits or do I need to find away to cool this beast down more?
post #6 of 6 Old 07-10-2002, 05:53 PM
Drafter75
Had a 4.0L in an 89 Cherokee. Temp normally ran just a tick under 210 on the gauge. On a hot day with AC, it could run anywhere between 210-225 in stop and go, then back down to 210 on the open highway. Obviously, it's important to keep your coolant fresh, at the proper level, etc... and it sounds like you are.
Since then, I've had 4 JGC's with 5.2L and 4.7L V8's... these all seem to run right in that same range. So like I said before, it's pretty normal and nothing to really worry about. On the other hand, you don't have much of a safety margin in case something happens to REALLY raise the coolant temp. I guess it's a matter of what you're comfortable with.
You may want to consider some type of aux trans cooler. This will help lower your overall temp and also help prevent a trans overtemp condition that will lockout your OD.
Drafter75
Poor heater temprature pearsonville4 ZJ Grand Cherokee Forum 1 12-14-2009 08:54 PM
Is this normal??? -cAcHe- ZJ Grand Cherokee Forum 3 10-22-2008 09:06 PM
Is it Normal for 01 GC? leoleo ZJ Grand Cherokee Forum 3 01-04-2007 05:58 PM
Engine running cool. A/C running hot. nike_sasquatch ZJ Grand Cherokee Forum 4 09-25-2006 09:34 AM
Is this normal? Rock1127 ZJ Grand Cherokee Forum 2 09-26-2005 10:12 PM
